Blender Cycles baking's margin overlap if multiple meshes are selected
Ubuntu 17.04 and GTX 1070
Blender 2.78.4
I have unfolded the UVs of all my assets with Texture Atlas to bake a lightmap. If I bake with Cycles and have multiple meshes that bakes on the same image Cycles will bake the meshes one by one at the sample set but will overwrite the previous baking with his margin because he loses the information of the UV placement of the other meshes. The only temporary way to avoid that is to reduce the margin and to increase the separation between each UV to avoid overlapping or to duplicate and join every assets to bake the lightmap.
Use two meshes seperated that share UV space, if the margin is higher than the UV separation the most recent mesh baked will overlap the others.
Danyl Bekhoucha (linko) updated the task description. (Show Details)
Aaron Carlisle (Blendify) triaged this task as Incomplete priority.Apr 15 2017, 10:52 PM
Please add a blend-file that can be used to reproduce the issue.
Fable Fox (fablefox) closed this task as Archived.May 4 2017, 8:02 AM
Fable Fox (fablefox) claimed this task.
No news in over a week... closing
