Individual Origins pivot mode messes up Shrink/Fatten
Closed, InvalidPublic
Broken: 2.78
As the title says basically. It seems that when you're using Individual pivot centers mode it doesn't do Shrink/Fatten much good.
  1. Open the File,
  2. Turn on Invidiual Origins (should be on already from me)
  3. Go into Edit Mode of the Cube
  4. Select the middle face loop (should be remembered as selection from me)
  5. Press Alt+S to trigger Shrink/Fatten
  6. All the faces go in one direction only
Could someone please check if this is a bug? Thanks! ;)
Hello. I did some tests and found that it got broken with the 2.7x series while it was working with previous 2.6x versions. Hope it helps.
This is working as intended, select multiple isolated regions to see how this is meant to be used.
