Black background on Cycles + Freestyle #51397
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#51397
Broken: 2.78c
When using Cycles + Freestyle on two different renderlayers, all I get is a black background instead of the expected alpha. I'm not sure if this is related to https://developer.blender.org/T43090 although it sounds like a similar issue.
PossibleCyclesFreestyleBug.blend
Added subscriber: @arcnor
Added subscriber: @zeauro
It is not the same bug.
Cycles requires Transparency option enabled under Film panel in Render Tab.
Without film transparency enabled, freestyle renderlayer background will be black.
Thank you, that certainly seems to fix the issue, although it makes all Renderlayers transparent (which is not the case in Blender Internal, although I'm not sure if that matters :D)... In any case, I guess this is not a real issue and can be closed.
Thanks.
