Wrong behaviour of property name used in a sensor #51404
Closed
opened 2017-05-03 18:30:40 +02:00 by Karja Krähwald · 5 comments
Windows 7 64, GTX980
Broken: e92f235283 + d187014 (2017-05-02)
Using a propertys name as sensor in this setup results in wrong output after starting the game engine:LogicBrickPropertyValueBug.png
Look at the sensor.
Picture 1 is wrong output, picture 2 is correct but with number 200 instead of "max", which should basically be the same, but it doesnt work.
In fact, "max" says 100 is greater than 200.
(Intention of setup is to not let "prop" go greater than "max")
LogicBrickPropertyValueBug.blend
**System Information** Windows 7 64, GTX980 **Blender Version** Broken: e92f235283 + d187014 (2017-05-02) **Short description of error** Using a propertys name as sensor in this setup results in wrong output after starting the game engine:![LogicBrickPropertyValueBug.png](https://archive.blender.org/developer/F586475/LogicBrickPropertyValueBug.png) Look at the sensor. Picture 1 is wrong output, picture 2 is correct but with number 200 instead of "max", which should basically be the same, but it doesnt work. In fact, "max" says 100 is greater than 200. (Intention of setup is to not let "prop" go greater than "max") **Exact steps for others to reproduce the error** [LogicBrickPropertyValueBug.blend](https://archive.blender.org/developer/F586479/LogicBrickPropertyValueBug.blend)
Added subscriber: @karja
Added subscriber: @dfelinto
Dalai Felinto self-assigned this 2017-05-22 14:49:21 +02:00
The Property sensor expects a raw value, not a property for comparison. In your case you can change your sensor by an "Always" sensor, and replace the "And" controller by an "Expression" controller: prop > max
The Property sensor expects a raw value, not a property for comparison. In your case you can change your sensor by an "Always" sensor, and replace the "And" controller by an "Expression" controller: `prop > max`
2 Participants
Reference: blender/blender#51404
