EnumProperty fill dynamically using callback
Closed, InvalidPublic
Not related (win 7)
2.78c hash e92f235283
I cannot describe it better : https://blender.stackexchange.com/questions/74453/enumproperty-fill-dynamically-using-callback
  • Create a Debug Anchor (3D view --> Add --> Debug --> Anchor)
  • Create a Camera (or use an existing one)
  • Select the camera, in the Object properties, use the "Point of interest" panel to add an Anchor and choose an existing one
  • Create a new Debug Anchor
  • Check the camera POI panel : the anchor previously chosen has changed
I don't see (3D view > Add > Debug ....)
Sorry, I mean : Add/Create a new object (Add menu from the default view) --> Debug object --> Anchor object
Yah, I don't have that at all. I've never see anything related to 'debug' in the add menu.
Are you using some kind of debug build?
I,
Sorry, I'm new to Blender's developer system, maybe my vocabulary is not good.
I just open the script and run it :
Blender stores enum properties as an integer internally. If you specify a list of items, the integer values will just be the location of the item in the list, which can change if you change the number of items. This is not considered a bug. Possible solutions are:
  • Explicitly specify an unique integer value for each item that you can guarantee stays the same, for example: ('NAME', 'Name', 'A description', 35)
  • Use a StringProperty instead, perhaps combined with prop_search to show a list of items in the UI.
  • In the upcoming Blender 2.79, PointerProperty will support pointing to datablocks (D113).
Thanks !
I didn't know it could work this way !
