Render Layers in compositor from a different scene not working
Broken: rB4cf7fc3b3a4d032f0c0db632a46d40806e906cf1
Worked: rB4cf7fc3b3a4d032f0c0db632a46d40806e906cf1^
Using scene layers from a different scene doesn't show the output sockets.
Open the file
and re-set the scene of the right-most layer to use scene "B".
This is what you get right when you open it, or in a commit prior to the bug:
This is what you get in new files, or after you re-set the (other) scene of the renderlayer:
Dalai Felinto (dfelinto) lowered the priority of this task from Unbreak Now! to 50.May 10 2017, 10:18 PM
Dalai Felinto (dfelinto) updated the task description. (Show Details)
I guess the two images are swapped? Anyways, I found the problem - the update code tried to update the nodetree of scene B, which doesn't have one. I guess I'll have to explicitly pass the nodetree that's supposed to be updated.
Thanks for the report, will be fixed in a second.
EDIT: Missed your image fix, sorry
