Eevee: Shader recompilation issue #51467
Reference: blender/blender#51467
The scene can be as simple as the initial scene with the initial cube. Set "use nodes" for the cube material and drag any of the material output node parameters. The slider dragging is not a smooth experience at all.
Added subscribers: @dfelinto, @fclem
I did some investigation, and I get the following results comparing Eevee and master. Note that the basic Eevee shader has ~ 5,000 lines of code, and master has ~ 3,500. Also, the tests below are focusing only on the shader. In Blender itself we also spend a considerable time in the GWN_shaderinterface_create() function.
Results
In Linux with an AMD Radeon RX480 running Mesa (Gallium 0.4 - 4.10.0-24-generic) we get:
Version: 4.5
Core profile: 1
That means Eevee shader compilation is taken 2x as much as master shaders. And those ~200ms means there is a big lag every time the shader is recompiled (e.g., when the user drags a slider in a node).
Running from within Blender I get a similar result, so this sandbox seems well representative of the real production environment.
In a NVIDIA Quadro K6000, proprietary driver 375.39 I get:
Now that's more interesting. While the master shader compiles faster, the eevee one compiles considerably slower.
Note: All tests were ran with __GL_SHADER_DISK_CACHE=0, so to prevent cached shaders from being used.
To run it for yourself, check the code on: https://github.com/dfelinto/opengl-sandbox
Added subscriber: @brecht
You could try removing unused functions from that
eevee.fp
and see if it's still slow. But since linking is not affected by unused functions, it's not going to help reduce that. Maybe some particularly problematic code can be identified by elimination.Looking at this [Unreal tutorial ]], it takes 3s (!) to update when they edit one value in the shader graph. They made shader compilation non-blocking so it's not as bad, and ideally we should do the same in Blender. Maybe it's slow because of the little shader preview renders or something else, but still makes you wonder if it can actually be made as fast as we would like. If you want instant feedback in Unreal, it seems you need to create [ https:*youtu.be/sx0BlzGkahw?list=PLZlv_N0_O1gbQjgY0nDwZNYe_N8IcYWS-&t=642 | material instances where some parameters become uniforms.
So perhaps your idea of compiling all node parameters as uniforms is really the main way to get better performance while creating the shader graph. A second more optimized shader with constants could be compiled in the background if needed. Ideally we could avoid users having to think about material instances to get faster feedback when tweaking shaders, but if we do need them then they could be node groups with sockets that you can't link to.
Added subscriber: @MikeErwin
I too think making uniforms for all parameters is the way to go, when editing or animating a material. Constant value nodes can be compiled for faster preview/playback when a material is not being edited. This is one area we can do better than the Unreal editor.
I think the performance issue in
should be fixed though, it's taking up 30% of compilation time here. It's not clear to me why Gawain caches all this data about uniforms and attributes, and the lookup by name has O(n²) behavior. If it's done for performance reasons then I don't think Gawain can do name -> location mappings much faster thanglGetUniformLocation()
. Caching of those locations needs to happen at a higher level to avoid that mapping entirely.As it turned out, we do can get some benefit from doing it. I updated the github program with a "lean" version of the Eevee shader, with only the needed functions.
Of course there is overhead on including only the required functions. And those numbers are for the simplest shader. We may not get so many things to trim down in a more production-ready material.
In Linux with an AMD Radeon RX480 running Mesa I get:
"Fixed" on
2a489273d7
by making uniforms out of all the nodetree inputs. I will close it for now, but I would still like to see the performance on GWN_shaderinterface_create addressed.Ok so I tried to see what causes the huge linking time and the answer is really not pleasing.
This is caused by the number of branching in the shader. So things like
518e768579
which basically double every eevee's branches roughly double the linking timeUsing the test program provided by @dfelinto I got theses results :
Current principled shader : 3011ms
Previous principled shader (without the branch) : 1781ms
Most of the shader branching complexity is inside the lamps evaluation. And the addition of the Cascaded shadow map lately increased this complexity.
To reduce the branching I can order lamps by type/shadow and iterate on each type one after the other like I do for the probes.
Reducing branching in lamps code could "hypotheticaly" get us to 1667ms. (I did a really short test bypassing all the "if"s and using the worst case).
But of course that will never be the case and I sense the end result will be more like 2000ms.
And removing the branching from the principle shader gets us to 1020ms. But this would remove the purpose of it's runtime optimisation.
Anyway this would still be higher than 1sec for each Material shader. So we REALLY need lazy shader compilation.
Here are the shader files if someone care to take a shot : eevee-huge.fp eevee-huge.vp eevee-huge-fixed.fp
Changed status from 'Resolved' to: 'Open'
Confirmed the really low times linking times due to branching. I even added a new
--debug-gpu-shaders
that for now dumps the compiled shaders in the Blender temp session folder.Changed status from 'Open' to: 'Resolved'
Lazy (Deferred) Shader compilation is in 2.8 for quite some time now. Closing...
