Remove gif images #51472
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#51472
.gif images should be removed from the manual. This can be done in several ways, adding more explaining text, create a video, create multiple images.
From https://docs.blender.org/manual/en/dev/about/contribute/style_guides/markup_guide.html#files
Added subscriber: @Blendify
Added subscriber: @RayMairlot
Is this meant to be tagged as a bug?
I do not think it really matters but I would say it is a bug as it causes issues with pdf generation.
The correct tagging of information allows said information to be accurately searched, which from a user perspective is important to be able to find existing bugs to prevent reporting duplicates. Personally, I would also think it's important from a developer perspective to make sure the ever important bug list is not populated with things which aren't bugs, but then I'm not a developer. I'd say this sounds more like a task, but if you're saying it's a bug, fair enough.
Added subscriber: @jenkm
Can anyone convert rendered image sequence to video and upload to youtube?
To replace this gif file:
24FPS-1280x720.zip
This issue was referenced by 3978
Removed subscriber: @RayMairlot
This issue was referenced by 4014
Committed rBM4069
