Tissue object tessalation addon: 2.79 Release #51508
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#51508
Hi this is the task for the tissue addon by Alessandro Zomparelli
https://blenderartists.org/forum/showthread.php?375378-tissue-by-Alessandro-Zomparelli
Initially I approached Alessandro Zomparelli in regards to adding his popular Tissue addon to 2.78 release but we were unable to solve issues.
I've been approached by Alessandro recently & tested the new addon & it's working much more suitably now.
code: https://github.com/alessandro-zomparelli/tissue
wiki: https://github.com/alessandro-zomparelli/tissue/wiki
Alessandro is well versed with Git usage & prepared to commit & maintain his addon in our repo.
Sorry for lateness, but this addon is worth breaking bcon3 rules (no new features) as it's a requested feature/addon from last release.
Just running a little late, will be done before test builds.
Thanks.
Added subscriber: @BrendonMurphy
Added subscriber: @AlessandroZomparelli
Hi Brendon,
I'm actually not much expert of managing large projects on github. I mainly developed small scripts because I'm a designer more than a programmer.
I will start cleaning up the code a bit. You also mentioned to format differently the props. Can you please be more specific?
Cheers
Hi Alessandro,
I can help with Blender git, really it's no different to github where you currently host & update your files.
I looked at your addon & there's many pep8 issues & Blender Code Style problems.
As these are not familiar to you atm, It might be best if I commit as is, then make style changes for you without any function changes.
From there you can grab the script from our repo & send back any changes you need here, or if you can, commit yourself.
You can learn about Blender git setup here;
http://wiki.blender.org/index.php/Dev:Doc/Tools/Git
http://wiki.blender.org/index.php/Dev:Doc/New_Committer_Info#Commit_Logs
https://wiki.blender.org/index.php/Dev:Doc/New_Developer_Info
Thanks, let me know how you would like to proceed.
Brendon
Yes, of course, if it is not too time consuming for you, I would be great. Then for future developments I can continue on the version committed by you preserving the style.
Or I can at least try to fix the pep8 issues before. Let me work just on that.
Ok, I did it. Now it should be better for PEP8. Please check if I missed something.
Alessandro
hi, I'll check it out now, thanks.
@AlessandroZomparelli hi, great job on the clean up. code looks much nicer now.
one last thing, the ccby license at top of file? I see you have the gpl ,license file also.
can we just add the standard gpl license block to the top of files?
Yes, sure. You mean that one?
My only concern is that according to that description I should add the license file... Is that true?
hi, that's it, just standard like that if you look at other addons
you can also add below ### Author Name, small notes.
Thanks
hi, made initial commit to release with some changes.
Fix gpl blocks & info.
Fix Duel mesh unreg
Change Tab name to Create tab (addons must default to existing tab names)
ToDo:
Add Panel rename code blocks
Close Panes by Default
Thanks, I hope everything is ok, we can keep this task open for followups.
closing as resolved, committed, testing well.
