Incorrect windows scaling - mouse offset from view - menu bar invisible
Windows 10 (1703)
Intel 7th gen HD graphics
Intel and Lenovo display drivers behave the same.
Lenovo ThinkPad Yoga 370 Intel Core i5 7th gen.
Broken:
2.68a 64 bit,
2.75a 32 and 64 bit,
2.77a 64 bit,
2.78c 64 bit,
2.78 f3d9f0c 64 bit both standard and the experimental vc14 compilers,
2.80 branch f637145 64 bit.
Worked: (I cannot find a version of Blender from the last few years that works with the latest Intel drivers!)
It works if I revert to an older version of the Intel HD drivers for 7th gen as suggested by @Dragon (someDragon).
Intel drivers version 15.45.16.4627 previous release 23 March 2017, works.
Added to the Intel developer support forum:
https://software.intel.com/en-us/forums/graphics-driver-bug-reporting/topic/735289#
Window layout does not fit the screen. The title bar appears to overlay the top menu bar. The positions are all offset like the graphics on display are a different size to the internal calculations. The mouse pointer needs to be a few millimetres under the screen button to be able to click on it!
The image attached best describes the issue. Note that there is no menu bar visible and the side bar is partly outside the window edge.
I suspect it is a specific hardware combination that causes the issue. 1920x1080. I've tried both the Lenovo and the Intel versions of the display drivers.
By default I have the Windows 10 display scaling set to the recommended 150% however I have tried changing the scaling to 100% and the behaviour of Blender is unchanged!
Related Objects
There are a very large number of changes, so older changes are hidden. Show Older Changes
I had the same problem on a new Dell Precision laptop. I downloaded Blender 2.77 windows 64 and everything is working correctly.
Update: I was wrong. 2.77 is not operating correctly
Fixed!
Had the same problem on a Win10 x64 Lenovo X1 Yoga with Intel HD Graphics 520. The 5/17/2017 21.20.16.4678 drivers seemed to break the UI.
However, I just updated to the 8/13/2017 22.20.16.4771 drivers and the issue is fixed. Edges of the UI are no longer cut off and the mouse alignment is corrected.
I'm also having this issue on Win10 x64 Lenovo X1 Yoga (2nd gen) with Intel HD Graphics 620. In the entire time I've had my laptop (since June 2017) I have had this issue.
I can't seem to find the correct driver version that MattPenner mentioned on Intel's site. Can someone share a link?
T (voxelv) added a comment.EditedSep 4 2017, 6:18 AM
I guess the Intel HD 620 Graphics has a different number (of course haha).
It wasn't as straightforward to install on the Lenovo ThinkPad X1 Yoga (2nd Gen) though. It kept saying something to the order of "This driver is not approved for your computer by its manufacturer" and wouldn't install.
EDIT: (I forgot the link): https://downloadcenter.intel.com/download/27058/Graphics-Intel-Graphics-Driver-for-Windows-15-46-?product=96551
In case others come here looking for a solution on the 2nd Gen, here's the steps I took:
  1. Open Device Manager
  2. Right Click Display Adapters -> Intel HD Graphics
  3. Properties -> Driver tab -> Update Driver button
  4. Use the "List of drivers on my computer" option
  5. Set to Microsoft Basic Driver. Note, your graphics may now be quite wonky because they aren't using the GPU...
  6. Install the new driver from Intel.
  7. Reboot.
  8. Done!
@T (voxelv) it is quite common for laptop vendors' drivers to warn that chipset manufacturer drivers are not approved.
The slightly tidier way, to achieve the same as you have described, is to completely uninstall the laptop vendors' drivers and then install a clean set of drivers from the chipset manufacturer. Intel in this case.
Regards
I have religiously stayed with the Lenovo System Update Utility just because I've ran into issues in the past (namely with Windows 8 and Miracast drivers) where reference drivers were incompatible compared to the vendor drivers.
However, in this case Lenovo was happy to tell me my system was up to date, and even wanted to suggest a different graphics driver when it noticed I had the reference driver loaded. So, I'm ignoring the System Update Utility for my graphics for the time being.
My update actually was a much easier process than described above. Not sure why. I went to the Device Manager, Display Adapters, right-clicked on my Intel(R) HD Graphics 520 device and selected Update Driver Software. Not sure where Windows looks compared to Lenovo but it loaded the Intel driver and all was fixed. Strangely as I mentioned above I have driver version 22.20.16.4771, yet the Intel website states 15.46.05.4771 is the latest.
@T (voxelv) and @Matt Penner (MattPenner) I take back what I said. My Lenovo was a pain to update. The new drivers kept claiming they did not support the operating system I was using.
Uninstalling the previous drivers kept reverting within a few seconds to an older version of the Intel drivers!
Thank you @T (voxelv) your method worked.
Regards
Sadly the new drivers no longer work in conjunction with a DisplayLink adaptor.
Previously, as long as I had the lid to the laptop open, I could use Blender on one of my external screens connected to a USB 3 DisplayLink dock.
Now Blender will only render on the laptop screen!
Disappointing.
I can confirm that rendering still works while using the ThinkPad OneLink+ dock, even with the laptop (X1 Yoga) closed. I've got two monitors both on DisplayPort and was able to render without an issue. I'm not sure how current the USB 3.0 dock drivers are. When my company used that with several older Lenovo X1 Carbons we had a few issues. For the most part they worked but I had to reboot weekly for the screens to show up and we had a couple that just died unexpectedly.
@Matt Penner (MattPenner) the OneLink+ connector is unique to Lenovo's as far as I know. Whereas DisplayLink is a chipset embedded inside nearly all USB 3 docks. It's advantage is that it works with nearly any laptop, the disadvantage is that it needs display drivers on the PC and these are not as powerful as the Intel HD chipset.
The DisplayLink based docks are OK for most corporate business uses but not optimised for graphic intensive applications.
At home I can just use a direct connect cable but at work that's not so convenient!
New drivers has resolved my issue, using Intel HD Graphics 520.
@Vuk Gardašević (lijenstina) With the number of these reports we're getting, perhaps it'd be a good idea to add a note to the release logs page (maybe under the compatability stuff) telling people with Intel cards to update their drivers if they get this problem?
@Joshua Leung (aligorith) I agree that is generally a good idea, however drivers/OS updates can break up all the versions of Blender and can happen months after the release.
I think that could be a topic for the next / some developer meeting in the future - where to place a web page with the known driver issues / affected hardware and how to make it known to the users.
Thanks @T (voxelv), this helped me fix it for now
I have this issue also but my graphics card says everything is up to date.
It's an Intel(R) HD Graphics 520 on Windows 10 Pro.
Can you try following the instructions from voxelv, it involves reinstalling the driver. I don't know if that helps since it says updated already for you, but go ahead and install it from Intel's website and reinstall it in the device manager
I am experiencing the same problems but I can't seem to fix them
Can anyone help please?
I have tried reinstalling the driver and checked it's up to date, but I still have the same issue.
I can replicate the same behavior.
Machine: Lenovo T 470, i7-7600U, Intel HD 620 integrated GPU, running on Dell P2414H through Lenovo dock
Tested with portable versions of 2.79b, 2.74, 2.65, 2.63 (random older versions), the same problem occurs all the time.
Tested with 100% and 125% scaling and various resolutions with no difference.
The interface looks "broken" (no top menu, preferences menu does not have tabs) and the mouse cursor is scaled off (near the bottom of the screen it tracks OK, but the higher I move the cursor, the bigger the offset is, up to 1-2cm off).
Can not update the driver due to not having admin privileges (at work).
qubodup added a subscriber: qubodup.EditedOct 25 2018, 9:57 AM
The issue is apparently caused by Intel´s drivers.
Does Blender have a policy regarding including detection, fixes and/or warnings for issues caused by 3rd party software?
SOLUTION:
  • Update the graphics driver.
For example installing: win64_25.20.100.6326.exe and restarting solves the issue on the computer I´m using right now, which has a Intel Iris Plus Graphics 640.
Requires Administrator rights.
WORKAROUND:
  • In Blender, press ALT+F11 (on some laptops: ALT+FN+F11)
This maximises the screen, removing the window title bar - which seems to be related to the displacement of the mouse position inside Blender.
Does not require administrator rights.
Video guide of both in case you need it: https://youtu.be/_rhJs2Brc-8
