overlapping vertices when cutting middle of the poligonal face
Closed, InvalidPublic
cut tool creates double vertices that need to be welded afterwards
it happens when i cut middle of the face of the polygonal object.
vertices do not snap to each other,they do not weld automatically sometimes,it creates double overlapped vertices.Knife tool fails to create proper vertices that would not be overlapped,sometimes when the knife tool is being used,overlapped vertexes come up.
overllaped vertex,created by knife tool
Szymon Warunek (szymi) created this object with edit policy "Szymon Warunek (szymi)".
Szymon Warunek (szymi) reopened this task as Open.
I ask if this bug can be resolved,as it is very frustrating to weld each overlaped vertex after using knife tool
Joel Godin (FloridaJo) raised the priority of this task from Confirmed, High to Needs Triage by Developer.May 17 2017, 2:16 AM
I'm not seeing that here.
Can you create a basic polygon on a new .blend and see if it happens there too. (see below)
I suspect there's something else going on.
For example, add a cylinder mesh, with the option Ngon for the ends.
Delete one end of the cylinder so you have just a round Ngon and create some cuts there.
Aaron Carlisle (Blendify) triaged this task as Needs Information from User priority.May 19 2017, 6:56 PM
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
