Windows: Missing numpy dll?
Closed, InvalidPublic
Windows 7
i7 3.8ghz
16gig quad channel RAM
gtx 900
Broken: (example: 2.69.7 4b206af, see splash screen)
Blender 2.7C 64 and 32bit
attempt to install addon, when enable addon box appears stating error{F603790}
mike cassidy (ZalNor) created this task.
seems to be missing file. please fix
Bastien Montagne (mont29) renamed this task from Traceback Error to Windows: Missing numpy dll?.May 19 2017, 12:51 PM
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Normal.
Bastien Montagne (mont29) triaged this task as Needs Information from User priority.May 19 2017, 12:54 PM
@LazyDodo (LazyDodo) error message seems to imply some missing numpy dll in windows build… Can you please double-check that? thanks.
@mike cassidy (ZalNor) did you try re-downloading and re-installing Blender, just to be sure it’s not some glitch from first installation?
numpy seems fine here, I need better repro steps , what addin is being installed? what version of blender is this on etc? marking as incomplete until more information is supplied.
I did re-install Blender
its was version 2.78c that I am using. I have tried both 32bit and 64 bit versions and having same error message.
it is the Auto-rig-pro addon from BlenderMarket that I have been trying to install
how I tried to install is same as all addons
User preferences - addons - install addon from file
I had the addon on my desktop - selected the .zip folder - add addon from file
the addon appeard, sometimes I had to search for it which was a bit odd never had to do this for any addon
when I click the activate addon check box the error appears
Note - I have not had any trouble with any other addon
I have had some trouble with non-blender based renderers which you can download via the blender website. only one I have tried was Aqsis renderer simillar error
What happens if you switch to the python console and type
import numpy
I havent tried that but will give it a go
ok I've just tried typing in "import numpy" and this is what I got
File "<blender_console>", line 1, in <module>
File "C:\Program Files\Blender Foundation\Blender\2.78\python\lib\site-packages\numpy\__init__.py", line 180, in <module>
  from . import add_newdocs
File "C:\Program Files\Blender Foundation\Blender\2.78\python\lib\site-packages\numpy\add_newdocs.py", line 13, in <module>
  from numpy.lib import add_newdoc
File "C:\Program Files\Blender Foundation\Blender\2.78\python\lib\site-packages\numpy\lib\__init__.py", line 8, in <module>
  from .type_check import *
File "C:\Program Files\Blender Foundation\Blender\2.78\python\lib\site-packages\numpy\lib\type_check.py", line 11, in <module>
  import numpy.core.numeric as _nx
File "C:\Program Files\Blender Foundation\Blender\2.78\python\lib\site-packages\numpy\core\__init__.py", line 21, in <module>
  from . import _internal  # for freeze programs
File "C:\Program Files\Blender Foundation\Blender\2.78\python\lib\site-packages\numpy\core\_internal.py", line 14, in <module>
  import ctypes
File "C:\Program Files\Blender Foundation\Blender\2.78\python\lib\ctypes\__init__.py", line 7, in <module>
  from _ctypes import Union, Structure, Array
ImportError: DLL load failed: %1 is not a valid Win32 application.
this was all red like an error
Strange.... if you grab a nightly from https://builder.blender.org/download/ same thing?
same message appears. although I unistalled my version of blender and it still has my user settings. how do I delete everything? there must be something stored somewhere this could be the issue?
there's a command line switch for that , blender --factory-startup
also try downloading a different build, if you normally use a 64 bit build, download a 32 bit one, see if that works (or the other way around)
also , do you happen to have anaconda installed?
I wonder if the same error is related to another bug T51446 ?
I have tried both 64bit and 32bit and had the same issue in both.
what is anaconda?
anaconda is open data science platform ( https://www.continuum.io/downloads ) that also uses python, but sometimes their setup interferes with our libraries.
I'm rapidly running out of ideas here's some more things you can try
  1. try running process monitor ( https://technet.microsoft.com/en-us/sysinternals/processmonitor.aspx ) while trying to load numpy , filter for the blender.exe process, save the data and attach to a post here
  2. Check your virus scanner? maybe it has a false positive and blocked some of the libraries?
  3. Check the windows event logs from around the time you get the error, it may have some additional information
The virus scanner could be the issue. I ran a FixMeStick not long ago and it reported a file as a virus so I told it to block that file but I can't remember if it was this one or not.
Fable Fox (fablefox) closed this task as Invalid.Jun 1 2017, 5:30 AM
Fable Fox (fablefox) claimed this task.
No more updates after admitting it could be a virus scanner issue. Closed.
