Denoising passes get inappropriate values with a volume in front. #51567
2 Participants
Reference: blender/blender#51567
If you have a volume in front of objects Denoising Depth and Normal passes gets the volumes surface not the surface behind. Interestingly enough it seems it treats it differently if you set a (completely - never tried something in between) transparent surface shader than "none" as surface. None is treated as a surface while transparent is not and gives the normal of the object behind (and a better denoising result).
If possible I think "None" should work as totally transparent. If this would not be possible I'd suggest adding a transparent surface shader as default to the "quick smoke" and writing this clearly as a known issue with a simple workaround. [If this is already clearly documentet my apoligies for not having noticed.]
I have a simple test scene which proves it, but I don't see where to add it. I tested this with buildbot build blender-2.78.0-git.6cd1d34-windows64 of today.
Added subscriber: @tobbew
tw_cycles_denoising_bug.blend This file shows the issue. (It does not matter if volumes are empty. They have the same material. Left has "None" surface, right has a transparent one.
Fixed with
3bf69b26ef
, thanks for the report.
