False positive error in Surface Deform modifier in some cases #51588
Reference: blender/blender#51588
intel i5 6400, Windows 10
2.78.5 hash
f3d9f0c
Using the Surface Deform modifier, error messages of overlapping verts or concave faces in the target mesh appear, even when the mesh has no overlapping verts or concave faces. The target mesh follows the rules of the documentation https://wiki.blender.org/index.php/User:Lucarood/SurfaceDeform
What's more bizzare, even though the documentation states that the modified mesh has no restrictions, the error disappears depending on the modified mesh used.
Since the error is hard to replicate from scratch with a new mesh, I've cut out the part of the mesh I was working on where the error happens.
Here are the things you can do to both replicate the error cases and the weird cases where the error doesn't happen.
The target mesh is the blue one and the rest are examples of meshes with the Surface Deform modifier
Case 1- Select the mesh called Modified 1 (the green one) or Modified 2 and press the Bind button in the modifier stack. The overlaping verts error should appear
Case 2- Select the mesh called Other (yellow Suzanne) and press the bind button in the modifier stack. It works and the error doesn't appear. So, it's not the target mesh?
Case 3- Move or resize the meshes Modified 1 or Modified 2 far enough, and press the bind button. It works fine. If you only move them a little, the error appears again
Case 4- Revert the file if you made any changes first. Select the target mesh (blue), go into Edit Mode and press X> Edge Loops (I already selected the loop). Go to Object Mode and select the red mesh, Modified 2, and press Bind. This time the error message is about concave faces. The green mesh works fine without errors, though.
Added subscriber: @moisessalvador
Added subscriber: @LucaRood-3
Added subscriber: @lichtwerk
Checked on this, all error messages on binding seem to be resolved and binding seems to behave normally.
Note: atm. you wont get modifier error messages in the UI, for that you'd need D6601: Fix (unreported) surface deform modifier not reporting its errors in the UI applied...
Anyways, this seems to have been resolved along the way, closing...
(feel free though to comment again if issues persist, we can always reopen in that case...)
