.mdd & .pc2 export leave unfreed mesh data in memory killing Blender on larger animations #51627
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#51627
For a project I needed to export a larger mesh animation either as .mdd or .pc2 file. I was unable to do so because the exporters ran out of memory. The reason is that they are creating a new mesh data block per each frame but not deleting them after the data has been written to file which leads to a steadily increasing memory consumption the longer the animation sequence gets.
Here is one example, try to export it in either format and monitor memory usage:
1_export.blend
The solution is a one-liner deleting the data block afterwards by bpy.data.meshes.remove().
Try above test again with this patch and note the difference: patch.diff
System: Windows 7 x64
Added subscriber: @KaiKostack-3
This issue was referenced by
51ee36db62
