Result from using curve taper/bevel objects not scaled properly when used in scene with 0.01 metric scene scale #51666
2 Participants
Reference: blender/blender#51666
Win8, GTX1070
Broken: 2.78
e92f235283
and recent 2.78 builds tooShort description of error
When selecting a taper object and a bevel object for a bezier curve in a scene with 0.01 metric scene scale it turns into a huge mess. I'm guessing it has something to do with the scale of the bevel object because if you scale it down 100 times the curve looks normal.
Expected result: (in scene with 1 metric scene scale)
Not expected result: (in scene with 0.01 metric scene scale)
.blend file: bug_curve_scene_scale_001.blend
Added subscriber: @cyaoeu
Added subscriber: @Sergey
This is how taper works -- it multiplies the bevel by a Y coordinate (in local object space) of point of curve used for taper. In your case thay Y coordinate goes up to about 24. This what makes your curve to look really big.
Thanks for the report, but it's not a bug. Maybe improvements are possible here, but those happens outside of the bug tracking process.
It doesn't make sense. The dimensions for the objects are the same in a scene with 1 scale or 0.01 scale, so why would the result be different?
If repeat the above process in a scene with 1 metric unit scale it looks fine. So why is it broken in 0.01 unit scale?
Unit system and scale factor is purely interface thing, which scales internal values by given scale factor and appends unit. This also affects the grid. But internally everything is stored and processed in Blender Units.
You can see the exact blender values if you set units to None and units scale to 1. Those would be the values Blender is operating with internally.
