IntegerSocket+Material view crashes blender. #51687
Reference: blender/blender#51687
Win7 (but it's irrelevant, all builds should do this)
Broken: latest master
When you add an integer socket to a cycles node-group, cycles is happy with it and it functions properly , however when you switch to the material view, blender instantly disappears with an access violation.
Open the attached blend, switch to material view
MaterialViewCrash.blend
I'm pretty sure this will end up in the 'not supported, don't do that' pile, but still it would be nice if we at-least not punish the user with an instant crash when this happens
Added subscriber: @LazyDodo
Added subscriber: @Secrop
Added subscriber: @mont29
Can confirm the crash, for some reason
node_get_stack()
returns NULL bNodeStack pointer for those integer sockets... :|Added subscriber: @Sergey
OK, this boils down to
node_exec_socket_use_stack()
in node_exec.c not knowing aboutSOCK_INT
socket type…@Sergey not sure what's best here? support integer sockets (which could easily be converted to float values)? Forbid creation of such sockets in shader tree (if possible)? Or just make
gpu_stack_from_data_list()
NULL-checking thebNodeStack
pointers? Later solution seams most straight forward to me…simply adding SOCK_INT to the node_exec_socket_use_stack() fixes this..
return ELEM(sock->type, SOCK_INT, SOCK_FLOAT, SOCK_VECTOR, SOCK_RGBA, SOCK_SHADER);
Adding SOCK_INT here won't be enough, might work in that specific case but will break in others, unless you also define conversions rules etc.
For now will commit some code to make GPU evaluation of nodetree resilient to unknown/unsupported socket types. Would consider adding support of Integer sockets here as a nice and (probably) easy TODO.
This issue was referenced by
528ae8885e
