Windows 10 Home, 64 bit, Geforce GTX 550 Ti
Broken: 2.78c
When manipulating an animated object that has rigid body physics and a delta transform, the delta transform is added again to the object
-Use the startup file
-Change the delta location of the Cube
-Enable Physics/Rigid Body
--Set to animated
-Move the current frame to 10
-Press G to grab the cube, or transform in any other way
--->The Cube position is moved the amount of "delta transform"
