Blender 2.80 EEVEE, Cycles, Clay Black Wall Graphical Glitch
  • Machine: Lenovo Thinkpad X220 Tablet Laptop
  • OS: Manjaro KDE
  • Graphics: Intel HD Graphics 3000
  • CPU: Intel i5-2520M
  • RAM: 8 GB
  • Branch: 2.80
  • Hash: 2ebde4c82bd
  • Date: 2017-06-05 20:05
Located on the Y-axis there appears to be a black wall. The wall is located underneath the grid and can be found in the startup file. The black wall goes on infinitely on the Y-axis and never stops. The black wall does not appear in the final render. This glitch appears in EEVEE, Cycles, and Clay. It does not appear in Internal or the Game engine.
  1. Start Blender 2.80.
  2. Close splash screen.
linux drivers somehow allow Intel HD Graphics 3000 to support OpenGL 3.3, even though Intel says it's impossible. But it seems it's only partiall support.
Please run blender from the command-line and paste the errors you have there.
(cc: @Mike Erwin (merwin) @Sergey Sharybin (sergey) another intel issue it seems, what to do about those?
Here is a log with --debug--gpu:
When I run in terminal I get this error:
[caden@Manjaro_Linux ~]$ /home/caden/Blender_2.80_DEV/blender
Read prefs: /home/caden/.config/blender/2.80/config/userpref.blend
Received X11 Error:
        error code:   178
        request code: 155
        minor code:   34
        error text:   GLXBadFBConfig
Received X11 Error:
        error code:   178
        request code: 155
        minor code:   34
Received X11 Error:
        error code:   178
        request code: 155
        minor code:   34
Received X11 Error:
        error code:   178
        request code: 155
        minor code:   34
Received X11 Error:
        error code:   178
        request code: 155
        minor code:   34
Received X11 Error:
        error code:   178
        request code: 155
        minor code:   34
found bundled python: /home/caden/Blender_2.80_DEV/2.80/python
Performance is very good on my big project however. ;)
When using this version entering edit mode and entering the object it gives me this error:
intel_do_flush_locked failed: Input/output error
The application then froze and so did my entire computer. I was able to exit the application before my entire computer became unusable and was able to type this in here.
This wall disappears if you turn on only render in the display panel.
Sergey Sharybin (sergey) triaged this task as Confirmed priority.Jul 8 2017, 3:31 PM
Sergey Sharybin (sergey) claimed this task.
Can reproduce the issue on my laptop. Will give it a closer look later.
