Blender crashes on loading specific file #51741
legacy module
legacy module
legacy module
Eevee & Viewport
legacy module
legacy module
legacy module
Rendering & Cycles
legacy module
legacy module
legacy project
2.81
legacy project
legacy project
BF Blender: 2.8
legacy project
BF Blender: After Release
legacy project
BF Blender: Next
legacy project
legacy project
legacy project
legacy project
legacy project
legacy project
legacy project
Platform: Windows
legacy project
legacy project
legacy project
Priority::Normal
Status::Archived
Status::Duplicate
Status::Resolved
Type::Bug
Type::Patch
Type::Report
Reference: archive/blender-file#51741
Windows 10 Pro x64
Intel i7-6900K
2x GTX 1080Ti (not currently in SLI)
64GB DDR4 RAM
Running off a 500GB SSD
2.78c Hash: e92f235283
Short description of errorpreview.blend
Whenever I open a particular file Blender will open the console, initialize the window, and then immediately terminate the window and the console. I have not been able to collect any error data. This file worked perfectly at the least on Friday, possibly on Monday. No internal hardware or software changes that I can recall since then.
This issue happens using 2.78c, 2.78, 2.77a etc, other files launch normally in all these versions.
Open the file using any method, including double-click, open with Ctrl-O or drag-and-drop
Added subscriber: @NoviceInDisguiseProductions
Added subscriber: @fablefox
Win 7 64 bit / GTX 750 / Blender 2.78c
I use File-> Open and it didn't crash. It shows Camera Perspective / Preview Render.
Added subscriber: @LazyDodo
can't reproduce either, try starting blender with the
--factory-startup
commandline option and see that resolves the problem.Added subscriber: @Zeirus
Tested with and without Blender Sensei on latest Blender for Win64 build 2.78.5 (hash 81d7ff8) - Windows 7 64 bit
Open normally with double click on file and no crash at all... loaded perfectly!
Issue has been resolved for now, I am unsure what exactly made this happen, however I am now convinced it is not a bug that can be easily replicated/fixed so a definite solution could be hard to find. For now, try running Blender from the command line with
--factory-startup
as recommended.@NoviceInDisguiseProductions , the parameter allow Blender to run in factory setting. so the issue could be in any add on you enabled / installed or other setting if you run Blender normally. So you could try use a new zip version of Blender, and try enable add-on one by one and see which could be the issue.
However, you are correct. Its not easily replicated or fixed, specially if it involve 3rd party add-on.
