extrude_face_region BMesh operator non-functioning argument
Windows 10 x64
Renderer: GeForce GTX 860M/PCIe/SSE2
Broken: 2.78.5 9f044cb
In API documentation it says that use_keep_orig argument of extrude_face_region bmesh operator should "keep original geometry". I. e. it should keep or remove original faces from which extrude has been made.
But it seems that it doesn't do anything.
  1. Open attached blend file:
  2. Use Run Script in text editor with use_keep_orig argument set to False
  3. Undo and repeat with use_keep_orig argument set to True
  4. You should see that the original face is kept in both cases
The value is used, this is more of a documentation issue, committed edit.
In the attached script replace geom=[f] with geom=[f, *f.edges] - then changing use_keep_orig works as expected.
