Blender 2.78c crashes on Mac OSX Sierra (10.12 ) - every time AND immediately
Operating system and graphics card:
Mac OS Sierra 10.12 INTEL GRAPHICS 4000 ( 2012 MacBook Air )
Broken: 2.78C build 14 june 2017
HANGS ON STARTUP or short after / hides interface ( panels disappear spontanouisly )
just download an start Blender
Blender 2.78c, and any previous version for that matter, also hangs on iMac OSX Sierra right after start-up.
Could you start Blender from terminal and tell us what console output looks like?
Vuk Gardašević (lijenstina) changed the title from "Blender 2.78c C.R.A.C.H.E.S on MAC osx S.I.E.R.R.A ( 10.12 ) ----- every time AND immediatly" to "Blender 2.78c crashes on Mac OSX Sierra (10.12 ) - every time AND immediately ".Jun 15 2017, 4:58 PM
Vuk Gardašević (lijenstina) edited the task description. (Show Details)
Blender crashes instantly on my computer too. Here is the Terminal output:
Color management: display "sRGB / BT.709" used by scene not found, setting to default ("sRGB").
Color management: scene view "Filmic Log Encoding Base" not found, setting default "Default".
Color management: scene look "Base Contrast" not found, setting default "None".
Color management: sequencer colorspace "sRGB EOTF" not found, will use default instead.
Read new prefs: /Users/danial/Library/Application Support/Blender/2.78/config/userpref.blend
found bundled python: /Applications/blender.app/Contents/MacOS/../Resources/2.78/python
addon not found: 'io_import_scene_mhx'
measureit: Imported multifiles
archimesh: Imported multifiles
blender(2937,0x7fffd539a3c0) malloc: *** error for object 0x10f519cc0: pointer being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
Abort trap: 6
@Danial (Danial) What is your default scene? Run blender --debug --factory-startup and see what is outcome of that.
Bastien Montagne (mont29) triaged this task as "Incomplete" priority.Jun 16 2017, 4:46 PM
My default scene was simply a camera and lamp. Running the terminal with the additions you said results in this output...
Switching to fully guarded memory allocator.
Blender 2.78 (sub 0)
Build: 2017-02-27 12:24:16 Darwin Release
argv[0] = /Applications/blender.app/Contents/MacOS/blender
argv[1] = --debug
argv[2] = --factory-startup
read file
  Version 272 sub 2 date unknown hash unknown
ordered
 OBCube
 OBLamp
 OBCamera
blender(6034,0x7fffd539a3c0) malloc: *** error for object 0x112a9fef0: pointer being freed was not allocated
Abort trap: 6
Arto Kitula (akitula) raised the priority of this task from "Incomplete" to "Needs Triage".Jun 18 2017, 11:22 PM
Just to make sure, which macOS Sierra version do you have? I can't reproduce here.
I have 10.12.5. It was running perfectly fine a month ago on 10.12.4.
Ok, I just have now and it comes up with the same Terminal output as before, only with different version numbers obviously.
UPDATE: I just got it working. I updated my CUDA drivers and it loaded without a hitch.
Arto Kitula (akitula) closed this task as "Resolved".Jun 22 2017, 1:06 PM
Ah. Having CUDA on non-nvidia platform is quite uncommon :)
But good to know, as there might be people using thunderbolt-pci chassis.
My iMac actually has a NVIDIA GeForce GT 755M 1024 MB :)
I have same issue, the 2.78C and 2.79 keep hang on when start up everytime, Imac with latest iOS, the situation starts when I upgrade blender to 2.78(on 2017.06.10) and open a blender file (download from bt, its a file create on 2015)
I try to use 2.77 and work 3 days until 2017.07.12 afternoon, when I click the world icon it crash...and keep crashing that way...
My client will be mad soon..
@wky (bolt2009), did you try the solution suggested here, upgrading the CUDA driver?
When try to open 2.78 in terminal with sudo, it returns following text:
blender(1052, 0x7fffe18f23c0) malloc: * error for object 0x10e261fc0: pointer being freed was not allocated
[1] 1051 abort
if run command line without sudo, it will be only different with:
[1] 952 abort
if I use 2.77 to continue my modeling, click world icon to crash keep happening everytime, but if I start a new file and everything just fine...but I've been working with that model for 3 month....My deadline are just in 2 weeks..
the Base Installer fix my problem, thank you very much
