Blender crashes while joining edit mode
Closed, InvalidPublic
Operating system : Windows 10
grapic card: Gigabyte Geforce Gtx 1060
Broken: 2.8(hash3c7355b)
Worked:2.7-2.78
Blender crashes in all engines while joining editmode/ manipulate a Mesh
no matter if it is a simple or complex scene
The Console prints out in various Engines :
Error:EXCEPTION_ACCESS_VIOLATION
and blender closes
Only Blender Internal Render and GE offers more detailed information:
GPUShader: compile error:
0(27) : warning C7555: 'varying' is deprecated, use 'in/out' instead
0(41) : error C7616: global variable gl_Vertex is removed after version 140
0(66) : error C7616: global variable gl_ClipVertex is removed after version 140
0(73) : error C7616: global variable gl_Color is removed after version 140
Just to be clear, if you simply run Blender with --factory-startup, select initial cube and go to edit mode things crash?
If so please attach the complete system-info (Help > Save System Info).
I have run blender with factory setup but the same error occurs.
It seems the gpu can´t find openGl
and here is the working version from 2.78{F643447}
First time reporting any error - Pretty much the same issue Windows 10 running Blender 2.8 - switched to Blender render, tab to edit mode & crashed. Earlier got as far as trying to edit object but not edges visible & crashed when I tried to select anything. Did the same every time I tried.
Also ran from CMD:
C:\Users\Godfrey\Downloads\blender-2.80-ac76a3c-win64\blender-2.80.0-git.ac76a3c-windows64>blender.exe
AL lib: (EE) UpdateDeviceParams: Failed to set 44100hz, got 48000hz instead
found bundled python: C:\Users\Godfrey\Downloads\blender-2.80-ac76a3c-win64\blender-2.80.0-git.ac76a3c-windows64\2.80\python
0(15) : warning C7555: 'varying' is deprecated, use 'in/out' instead
0(45) : error C7616: global variable gl_Normal is removed after version 140
0(28) : warning C7555: 'varying' is deprecated, use 'in/out' instead
0(42) : error C7616: global variable gl_Vertex is removed after version 140
0(67) : error C7616: global variable gl_ClipVertex is removed after version 140
0(74) : error C7616: global variable gl_Color is removed after version 140
Error: EXCEPTION_ACCESS_VIOLATION
it always displayed like this :
Dalai Felinto (dfelinto) closed this task as "Invalid".Jul 18 2017, 11:06 AM
Dalai Felinto (dfelinto) claimed this task.
You are using Blender Internal. DON'T. Use Eevee or clay instead.
