VSE BoolProperties toggle when assigned False
Windows 10, ATI Mobility Radeon HD 4500 Series
Broken: 2.78c
Assigning False to ImageSequence.use_translation or .use_crop toggles between True and False
  1. Create an Image strip in the VSE and type N
  2. Execute in console:
>>> X=C.selected_editable_sequences[0]
>>> X.use_proxy
False
>>> X.use_proxy=False
>>> X.use_proxy
True
>>> X.use_proxy=False
>>> X.use_proxy
False
>>> X.use_proxy=False
>>> X.use_proxy
True
The same problem occurs with .use_crop or .use_proxy
The problem does NOT occur with e.g. with RenderSettings.use_antialiasing
P.S. Blender crashes when I open die attached .blend file.
