bpy.ops.screenshot() provoke error if python script is called as command line argument #51983
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#51983
Ubuntu 16.04, Intel HD Graphics 530
Broken: 2.78.c (from ppa)
Broken: 2.76 (from Ubuntu repos)
Short description
When Blender is launched from command line, with "--python" option (with ou without "--background" option), script is executed before UI is ready so ops like screenshot cannot be made while the same code works when running within Blender !
Exact steps to reproduce the error
Working:
1/ Start Blender (from shortcut, toolbar or Ubuntu dash)
2/ Load attached screenshot.blend (minimalistic file with python script embedded inside)
3/ Switch to "Scripting" screen layout
3/ Click "Run Script" : Warning is emitted but screenshot is generated and stored in your $HOME directory (since provided path is "." as second parameter of my own screenshot() call)
(didn't find the way to fix this last warning)
Working:
1/ From your terminal, call
(see blend file attached)
2/ Switch to "Scripting" screen layout
3/ Click "Run Script" : same warning is emitted but screenshot is generated and stored in current directory
NOT working:
(see attached file, same code as the one embedded in the provided blend file)
2/ A screenshot is generated containing an empty window filled with default color (gray by default)
NOT working: (alternative with same result as previous one)
NOT working:
2/ Crash, no screenshot generated
(unable to find what is incorrect in the context, probably associated to the fact the UI is not ready when script is executed)
NOT working : (by the way)
If you uncomment the code trying to find a workaround playing with applications handlers (at bottom of provided file or inside Text editor), you'll find that load_pre or load_post are not raised when blender is called with a script from command line !
Thanks for your work. Blender is great, I'm trying to use it as an alternative to limited solution like OpenScad. I would like to be able to customize the UI to have a multiaxis view and make screenshots of the full window (or some areas depending on scenario) to "debug" 3D printed objects, being able (example) to "see" / check (step by step + different view angles) if the selected edge loop is the good one before extrusion and by "selection" I mean the edges highligthed (selected) before manipulation (so rendering and saving it is not a valid alternative). Not to mention the fact that fixing this bug can help a lot to automatize screen capture for tutorials !
screenshot.blend screenshot.py
Added subscriber: @ntuxer
Added subscriber: @Sergey
The warning is caused by script trying to trick the system and override the context, that context is likely in inconsistent state. When running screenshot from the interface you don't need to override any of the contexts.
All the scripts passed via command line argument are executed at command line processing time, prior to any OpenGL draw is done. The screenshot operator itself is just reading OpenGL buffer,m without doing any actual drawing (it can't draw anything since that'd be unsafe).
When running blender in background mode, there is no window created, which also means there is no OpenGL context. You can;t use screenshot in such configuration.
So thanks for the report, but it's just limitation which can not be easily bypassed.
Thanks for your answer but, forgetting "--background" option (1st and 2nd "NOT working" cases), why are these commands not being able to a take valid screenshot since the UI is launched and can be modified by my script as you can test if you uncomment corresponding lines (so the OpenGL buffer should be readable as you mentioned, since Blender is not started in background) ?
As mentioned above, UI is launched but is not being drawn at the time when your script runs.
Thanks for your precision
