F-Curve "Stepped interpolation" modifier "restrict frame-range" IN and OUT parameters broken.
Windows 8.1, AMD Radeon HD 7480D
Broken: Blender 2.78.5 0172ed8
"Stepped interpolation" F-Curve modifier "restrict frame-range" IN and OUT parameters cannot be setted to values other than zero.
Open .blend file and try to change IN or OUT values.
Konstantin (Ko) changed the title from "F-Curve modifier "restrict frame-range" IN and OUT parameters broken." to "F-Curve "Stepped interpolation" modifier "restrict frame-range" IN and OUT parameters broken.".Jul 9 2017, 10:09 PM
Joshua Leung (aligorith) triaged this task as "Confirmed" priority.Jul 11 2017, 7:36 AM
Joshua Leung (aligorith) claimed this task.
Strange... investigating now...
Just to reiterate a note I made in the commit -- You'll need to manually click on the start and end frame properties of the Stepped FModifier to flush the relevant changes.
