Bake Action inaccurate for Spline IK
Windows 8.1 64 bit; EVGA GTX 970
Broken: (2.78c e92f235283)
Worked: Unknown
Hi Blender developer team,
I just wanted to report an issue I've discovered regarding baking actions on a rig that uses a Spline IK chain. Firstly, the rig is setup correctly: I have a Control Rig that uses 2 bones as Hooks to control a Bezier Curve; then I have a separate Deform Rig that contains the Spline IK chain which has the Bezier Curve set as its target. All other bones in the Deform Rig have copy transform constraints which point back to their duplicate bones in the Control Rig. This avoids cyclic dependency issues.
However, the deform rig is the one that needs to be exported with all the animation applied for use in another program. This requires baking each action into the deform rig, since the deform rig actually has no animation data of its own. So, for each action in the Control Rig, I would duplicate the Deform Rig, and name it Export Rig. I would then Bake the Action using the following settings:
After the bake, I began to notice a discrepancy in the bone positions of those which had been Spline IK bones. Interestingly, sometimes I could get it to work perfectly, usually by adding a visual keying LocRotScale keyframe first. But sometimes, that didn't work, and Blender had to be closed and re-opened. And sometimes THAT didn't work either, resulting in the final workaround which was manually adding a Visual LocRotScale keyframe for all bones in the Export Rig for EACH frame, and then baking the action (except with the "Overwrite" checkbox selected in the Bake Actions options). Essentially, that last step of baking was probably unneeded, but I did it as a quick way to remove all constraints. You can see the difference below, the selected (blue) rig is the baked one, and in the 2nd picture, you can see the baked and unbaked rigs line up perfectly:
Thanks so much for looking into this.
Sincerely,
Adam Janz
I can confirm there is still a very slight discrepancy (basically negligible) at times even when manually setting visual LocRotScale keyframes and then clearing all constraints manually using Ctrl Alt C. This is likely the nature of Blender not being able to truly pinpoint the position of bones affected by the Spline IK constraint after visually keying. However, there is no doubt something wrong with the way Bake Action does the visual keying on Spline IK affected bones, as 9/10 times there is a fairly large discrepancy.
-Adam
Here's a first guess at what may be happening (without having checked the file or the Bake Action operator):
It's likely that because the pose gets evaluated again for each bone (in order to compute what effect the visual keying should have), the results of the previous bone in the chain (that got keyed first) will end up influencing the results for latter bones, causing drift in the results. IIRC, there are similar problems with certain operations for the IK constraint.
Thanks Joshua and Brendon for your input. I did notice that manually setting visual LocRotScale keyframes and then hitting Bake Action produced much more accurate (but not perfect) results than just hitting Ctrl Alt C to clear the contraints. Maybe because the visual keying gets applied twice?
Joshua Leung (aligorith) lowered the priority of this task from 90 to Normal.Jul 17 2017, 5:11 PM
Indeed, I'd be very surprised if this was related to T51971.
I'm having the same problem when trying to export a complex rig to FBX. From what I can see, the problem could be related to the scaling of the bones. In other words, the scale of the parent bone affects the transforms of the child bone, thus, rotations end up looking totally sheared. I really don't know what kind of math could solve this, but it seems a pretty nasty issue if you are exporting things to a game engine.
So far, the only way I could manage to get an undistorted result, was to make all the bones children of the root bone, therefore making each bone independent from each other. Of course, this would not be what you wanted if you were planning on setting up an IK chain inside of the target Game Engine...
Hi Juan, you might be encountering this issue? If so, I posted a workaround; and there is also a solution inside UE4 if you are using that game engine. I hope this helps!
Hi Adam! Thanks for the link!
And yes, I found a similar solution, I also had a couple of bones moving like crazy in the export, so in my case I added some new parent bones that wouldn't scale along wit the rig, but would only copy rotation and location. From what I see, the main issue is with scaling.
You're welcome! Glad you got it working. :-)
Hi!
For those reading later:
I had a similar problem with baking spline IK and found a really easy fix that worked perfectly at least in my situation:
Take the armature to edit mode and remove the "inherit scale" checkbox from each bone. After this the baking works perfectly (bake action-->"visual keying", "clear constraints" and "replace action" checked.)
Thanks Andy for sharing that tip! :)
-Adam
If disabling Inherit Scale fixes this, it may be related to T54159. Basically, inherited non-uniform scale plus local rotation fundamentally creates shear, and it's impossible to avoid except by only using uniform scale, or not inheriting scale.
We should probably disable Inherit Scale by default for new bones? It doesn't really solve the bug, but might avoid the problem in most cases. I except that usually you don't even want to inherit scale from parent bones anyway.
Reasons not to do it:
  • Inheriting uniform scale is perfectly fine.
  • Usually you'd expect resizing your character root bone to work.
  • When not all checkboxes are enabled the code uses more advanced math to do it, instead of just simply multiplying matrices.
  • I wonder if export file formats for bone animations actually support these checkboxes - if they only can support full parenting, this would be pointless.
The real cause of user confusion in this case is that constraints, by working directly on matrices, can produce transformations that cannot be replicated using LocRotScale channels. I.e. inheriting scale induces shear into the local coordinate space, but constraints like Stretch To remove it from the world matrix, and this ends up impossible to bake.
I agree with Alexander, the inherit scale option shouldn't be turned off by default. You want it to be on in 99% of the cases.
Unfortunately, I just tested this and though baking within Blender is in fact fixed by turning off the inherit scale option, FBX export seems to ignore this option and bones get exported with shearing nevertheless.
The only way to avoid shearing is to actually unparent all bones, but though that would export things correctly, visually speaking, you lose hierarchies, and that results in an armature that can't get used in the game engine to add an IK constraints and stuff.
So, this seems to answer my last point :)
Do you know how game engines deal with the non-uniform scaling problem? Or is non-uniform scaling simply not used in game animation due to this, thus making any rigs using Stretch To or other similar mechanisms in effect not suitable for games? The shear problem is a fundamental aspect of any system that uses matrix multiplication based parenting.
I tested an FBX export as well and there was indeed a slight discrepancy when I brought the file to Unity. Juan, could you describe the unparenting process in more detail? I tried unparenting the bones from each other both before and after baking and the results were messed up in both cases.
I've used a rig with squash and stretch animations in UE4 which had a stretch to constraint in Blender. However, you can run into problems with undesired bones also stretching based on the parenting relationship. I posted a workaround here, and also someone found an alternate solution inside UE4.
Andy, what I mean is that all bones should be parented to the root bone or some bone that doesn't scale. When you do that, the result is more or less reliable, although it's never 100% correct for some reason.
Juan but is it really possible to get spline IK to work without a standard bone to bone parent hierarchy?
Andy, well, yes, the thing is that you've gotta have a control armature and a deformation armature. So, in the control armature you set all the constraints up, spline IK and stuff. When you have everything working, you create the deformation armature that consists of bones that might be parented just to the root so that they don't have a child/parent hierarchy. You then add a copy transforms constraint to each of those bones, pointing to the spline IK bones of the control armature. That way the deformation armature will mimic exactly what the control armature does, but it won't have a hierarchy that ruins the export.
From my experience, you might want to use a copy loc + copy rot + copy scale + damped track + stretch to constraint on each of the deformation bones, instead of just a copy transforms constraint. This has given me better results on export.
Finally for exporting, you just select the mesh and the deformation armature, you don't export the control armature.
That's strange. Although one thing about Stretch To is that it rebuilds the matrix from scratch, so it is guaranteed to be pure loc+rot+scale.
Edit: So I wonder what if you use Copy Transforms + redundant Stretch To.
Thanks for the answer Juan, that clears it up for me!
Sybren A. Stüvel (sybren) closed this task as Archived.Jan 9 2020, 5:53 PM
Sybren A. Stüvel (sybren) claimed this task.
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, and a minimal .blend file with exact steps to reproduce the problem.
