Blender 2.78 crashing on startup
Closed, InvalidPublic
OS: Windows 10 64-bit, latest version. GPU: NVIDIA Geforce GTX 970M, latest driver.
Broken: (2.78)
Worked: none (fresh install, new user)
When trying to run blender, a command prompt box opens up saying "AL lib: (EE) UpdateDeviceParams: Failed to set 44100hz, got 48000hz instead" for about 2-3 seconds, followed by "Error: EXCEPTION_ACCESS_VIOLATION". The command window then closes abruptly.
No error log is generated in the Temp folder as reported by other users with the same issue. However, every time the crash occurs it generates an empty folder named "blender_a12345", with a random five-digit number. These folders have no error logs or files in them at all.
I have tried running it as an administrator, no change whatsoever.
I have also tried reinstalling several times using both the .zip and the installer, and have installed both 64-bit and 32-bit versions, to no avail.
I have tried installing an older version of Blender (2.70a). After doing so, the command prompt comes up with no text, then blender opens up as a large white window, then instantly crashes with a windows-default "Blender.exe has stopped working" message. Still no error log generated.
I do not know how to replicate this issue. I simply installed blender 2.78 directly from the official website and am trying to run the program, which instantly crashes every time.
Bastien Montagne (mont29) triaged this task as "Incomplete" priority.Jul 18 2017, 9:32 AM
Did you try the latest build from our buildbot? This sounds like driver issue, so may not fix anything - but hopefully should give nicer error message, if it’s a GPU issue…
To get driver issue out of the way, you can try software rendering.
Try replacing the opengl driver with a software version from
http://download.blender.org/ftp/sergey/softwaregl/win64/opengl32.dll
just copy the dll into your blender folder (and remove it when you are done testing, performance will be very bad otherwise) and see if that improves things.
Fable Fox (fablefox) closed this task as "Invalid".Jul 27 2017, 4:31 AM
Fable Fox (fablefox) claimed this task.
More than a week passed without a reply.
Due to the tracker policy, archiving until the required additional information / data is provided.
I got the same problem, too. need resolve
