Blender crash #52165
Closed
opened 2017-07-24 00:15:39 +02:00 by Matthew Dougherty · 12 comments
Two Mac Pros, current OS
Mac Pro (Late 2013)
3.7 GHz Quad-Core Intel Xeon E5
16 GB 1866 MHz DDR3
AMD FirePro D500 3072 MB
Mac Pro (Late 2013)
3.5 GHz 6-Core Intel Xeon E5
64 GB 1600 MHz DDR3 ECC
AMD FirePro D300 2048 MB
2.78
standard defaults, not experimental mode.
rendering the same blend file on two mac pro's, not connected as render farm, both are standalone.
the 64GB has consistently crashed after 200-1200 frames on several projects.
The 16GB has not crashed, ever.
not sure how to further analyze problem.
unknown
**System Information** Two Mac Pros, current OS Mac Pro (Late 2013) 3.7 GHz Quad-Core Intel Xeon E5 16 GB 1866 MHz DDR3 AMD FirePro [D500](https://archive.blender.org/developer/D500) 3072 MB Mac Pro (Late 2013) 3.5 GHz 6-Core Intel Xeon E5 64 GB 1600 MHz DDR3 ECC AMD FirePro [D300](https://archive.blender.org/developer/D300) 2048 MB **Blender Version** 2.78 standard defaults, not experimental mode. **Short description of error** rendering the same blend file on two mac pro's, not connected as render farm, both are standalone. the 64GB has consistently crashed after 200-1200 frames on several projects. The 16GB has not crashed, ever. not sure how to further analyze problem. **Exact steps for others to reproduce the error** unknown
Added subscriber: @matthewd
Member
Added subscriber: @LazyDodo
Member
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
A guideline for making a good bug report can be found here: https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports
Marking as "Incomplete" until the requested information/data is provided.
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc. A guideline for making a good bug report can be found here: https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports Marking as "Incomplete" until the requested information/data is provided.
not sure how to proceed. Looked at bug reports URL. provided as much info as I have.
There is a good possibility it is a hardware ram problem, or some other intermittent hardware-meets-blender problem; not failing on other applications. On one crash it took out the OS.
Trying to get advice how to triage out blender bug as cause.
The blend file is over 500MB and seems to fail only on one machine. Doubt anyone is going to replicate problem, or be able to dig deeper as to cause except on the machine it is failing on.
Need advice on how to diagnose this to determine if it is really a blender problem.
not sure how to proceed. Looked at bug reports URL. provided as much info as I have. There is a good possibility it is a hardware ram problem, or some other intermittent hardware-meets-blender problem; not failing on other applications. On one crash it took out the OS. Trying to get advice how to triage out blender bug as cause. The blend file is over 500MB and seems to fail only on one machine. Doubt anyone is going to replicate problem, or be able to dig deeper as to cause except on the machine it is failing on. Need advice on how to diagnose this to determine if it is really a blender problem.
Added subscriber: @brecht
Do you have a crash log that you can attach to this report? Two places to look:
  • In the Console application on macOS, under System Reports.
  • In the Finder, Go > Go To Folder ... > type "/tmp", there may be a crash log written by Blender.
I assume you are using Cycles for rendering, is that using the CPU or AMD GPU?
Do you have a crash log that you can attach to this report? Two places to look: * In the Console application on macOS, under System Reports. * In the Finder, Go > Go To Folder ... > type "/tmp", there may be a crash log written by Blender. I assume you are using Cycles for rendering, is that using the CPU or AMD GPU?
Using cycles, render is set for CPU.
I looked for the crash log in the folder of the blend file, nothing.
will look at the other locations, thanks.
referencing https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports
"However if the bug randomly happens without any clear steps leading up to it, then it is unlikely developers will be able to fix the bug."
I have feeling this is going end up here, being that a lesser machine can render without fail, and the superior machine fails.
Using cycles, render is set for CPU. I looked for the crash log in the folder of the blend file, nothing. will look at the other locations, thanks. referencing https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports "However if the bug randomly happens without any clear steps leading up to it, then it is unlikely developers will be able to fix the bug." I have feeling this is going end up here, being that a lesser machine can render without fail, and the superior machine fails.
Member
if you can share the .blend that is causing issues that might also help
Added subscriber: @mont29
Bastien Montagne self-assigned this 2017-08-01 22:52:29 +02:00
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
Reference: blender/blender#52165
