Bug with enabling themes or specific addons #52204
Reference: blender/blender#52204
Windows 10, GTX 980
Broken: (2.78c, 2.78.5)
Worked: (2.8)
Something is wrong with enabling specific addons as well as themes.
ImportError: DLL load failed: %1 is not a valid Win32 application.
I tried uninstalling and reinstalling, downloading latest builds, doing factory reset and saving the default startup file.
Open user preferences,
Click themes tab,
Choose different theme
Click addons tab,
Click check box next to Add Mesh: A.N.T.Landscape
Added subscriber: @mswanston
Added subscriber: @VukGardasevic
Did you download the
Experimental Build Branch by VS 2015
build?From the section marked as 2) here:
If so, please chose a build from the 1st section marked with the Official tag to see if the error is present.
The VS2015 builds are still experimental as they can have some issues not present in the officially supported compiler.
Marked as incomplete until additional information is provided.
I tried all of the versions actually, the only one that seemed to work correctly was the 2.8 branch. All other versions had the same errors.
Added subscribers: @LazyDodo, @Sergey
I can not reproduce the issue on Windows 7 laptop. Don't currently have access to Windows 10.
@LazyDodo, mind having a test here? Thanks!
I'm also still on 7, and can't seem to repro either, but since this seems limited to 2.78 and your system, i'm suspecting there's something wonky in your profile folder, can you try
Shut down blender.
rename C:\Users[your username]\AppData\Roaming\Blender Foundation\Blender\2.78
to
C:\Users[your username]\AppData\Roaming\Blender Foundation\Blender\2.78.bak
Wow thank you very much, that definitely worked! So adding the .bak is a way to completely reset Blender?
i didn't want to delete anything, so i had you rename it, but yeah if you remove/rename/move the 2.78 folder it'll start over with a clean slate.
Oh gotcha, well thanks again. That was driving me crazy!
