MeasureIt not updating mesh positioning after first render, Error in remapping process, and ensure_lookup_table bugs #52236
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#52236
Windows 10, Intel HD 4600
Reproducible in both 2.78.5 e982ebd and 09eac01
Bug 1 - Fixed with
059aa14163
Mesh data is not changed after using the addon's built in render feature. After the first render, only changes to MeasureIt's open GL information will be captured in future renders (the mesh data stays the same).
Open the UV image editor and load the newly rendered image
3D View before second render
Second render output
Bug 2 - Fixed with
8068085bda
Somewhat related to Bug 1, after rendering an image with MeasureIt and pulling the rendered image up in the UV / Image Editor, if you go back into the 3D View and click MeasureIt's "Render" button a second time this error shows up in the console:
Click the "Render" button in the "MeasureIt Render" sub panel again to re-render the scene
Bug 3 - Fixed with
69cb19cf71
Editing the mesh that is part of a calculate measured segments will throw an "ensure_lookup_table" error if the segments are part of a Sum group. Sample error message:
Added subscriber: @nBurn
Added subscribers: @BrendonMurphy, @VukGardasevic
lijenstina also reported the following two errors to the Blender Console when MeasureIt was being used, but I did not include the second in the task description as I have not yet figured out exactly what causing it to show up:
Error 1:
Error 2:
@antoniov
I pushed a partial fix that should fix the Bug 1, but (if you can) could you please give this commit a quick look over (mainly the changes in measureit_main.py):
https://developer.blender.org/rBA059aa141639c93f075f2d75b5ff509d590a7219b
MeasureIt not updating mesh positioning after first renderto MeasureIt not updating mesh positioning after first render, Error in remapping process, and ensure_lookup_table bugsThis issue was referenced by
8068085bda
