Import-Export: unreal Skeleton Mesh = Error #52302
Closed
opened 2017-08-08 20:47:05 +02:00 by karim · 6 comments
Operating system = 15063.483
Graphics card = -
Broken: 2.79
```  -> The export tool "Unreal skeleton Mesh" don't show up in the export selection even when I marked the button in the Blender User preferences.
**System Information** Operating system = 15063.483 Graphics card = - **Blender Version** Broken: 2.79 Worked: (optional) **Short description of error** ``` ``` -> The export tool "Unreal skeleton Mesh" don't show up in the export selection even when I marked the button in the Blender User preferences. ``` **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps
Author
Author
Added subscriber: @Layriu
Added subscriber: @VukGardasevic
Could not recreate it on Win 7 with 2.79 RC 1
Please can you see if there are any error messages in the console by going to Window > Toggle System Console ?
Do you have imported some configuration files from the previous Blender versions?
If so, try to go to File > Load Factory settings and then later on enable the add-on in question?
Does the UDK export panel show up in the ToolShelf area (on the left accessible with T) under the File I/O tab?
Setting as incomplete until additional information is provided.
Could not recreate it on Win 7 with 2.79 RC 1 Please can you see if there are any error messages in the console by going to` Window > Toggle System Console` ? Do you have imported some configuration files from the previous Blender versions? If so, try to go to File > Load Factory settings and then later on enable the add-on in question? Does the `UDK export` panel show up in the ToolShelf area (on the left accessible with T) under the File I/O tab? Setting as incomplete until additional information is provided.
Vuk Gardašević self-assigned this 2017-08-15 19:09:17 +02:00
More than a week passed without a reply.
Due to the tracker policy, archiving until the required additional information / data is provided.
More than a week passed without a reply. Due to the tracker policy, archiving until the required additional information / data is provided.
2 Participants
Reference: blender/blender-addons#52302
