Worse render result with Russian Roulette Termination #52313
5 Participants
Reference: blender/blender#52313
Using Russian Roulette sometimes results noticeably more noise (build
6af7d7e
) than regular probabilistic termination in Blender 2.79 RC1 with the same render time.6af7d7e
(512 SPP, 54.05 s)6af7d7e
equal time (670 SPP, 69.59 s)Max and min samples were set to 8 and 4 respectively in RC1.
monument5 279rr.blend
A second scene tested with build
4d428d1
exhibits the same results.4d428d1
(256SPP, 24.13s)4d428d1
equal time (380SPP, 35.28s)TESTmonument3-RR.blend
Added subscriber: @pixelgrapher
Added subscribers: @brecht, @Sergey
@brecht, think solution here could be to use curve with a bit "steeper" tangent when close to 0. Experimented a bit with
sqrtf(sqrtf(max_throughput))
andcolor_scene_linear_to_srgb(max_throughput)
. This scene seems to behave better. Think we can use some simplified version of sRGB-like curve, maybepow(max_throughput, 1.0 / 3.0)
.Optimizing the curve for this scene is going to make it worse in others. I'll do some tests with other exponents as suggested, but importance sampling will always make some scenes worse so it's a matter of figuring out what works best on average, and some scenes will inevitably be worse.
In this specific scene, the image converges poorly due to caustics, which can be solved by setting Filter Glossy to 1. Without that, more samples actually make the image more noisy in some ways, because more fireflies start appearing.
Note that the optimal choice may also be different once we have adaptive sampling, since that gives you more leeway to risk noise in some areas of the image if it speeds up other bigger areas a lot.
I'm not sure if that's an excuse on current termination or not. If so, then it just doesn't sound right. We should not leave users with a more noisy renders just because somewhere in the future we might possibly have adaptive sampling. If we add adaptive sampling, then we can re-tweak termination criteria to what works best with it. Don't see anything wrong or bad with that.
I'm not saying the suggested changes are the way to go, just saying there is room for possible improvements, but surely more investigation needed.
P.S. While we are on this piece of code again, it feels like name
path_state_terminate_probability()
is inverted. It's more likepath_state_keep_ray_active_probability()
. It is confusing that terminate probability of 1.0 doesn't terminate, but keeps ray active.Not saying that we should tweak it for adaptive sampling now, just mentioning it as something to keep an eye on.
I think the standard term would be "continuation probability".
I did a lot of tests here with different powers and formulas, and didn't find anything that seems clearly better overall than what we have now. If we gradually make termination more conservative, noise in this scene goes down gradually but render time in other benchmark scenes goes up gradually too. There does not appear to be any magic point that gets us the best of both worlds. For now I'll just consider this a trade-off we do to make rendering scenes faster on average, even if it's worse for some scenes. I also suggest to just use filter glossy, which is enabled by default now, to get rid of the main source of noise in this scene.
Is it possible to offer both the original and new termination methods available for the artist to optimise at their own discretion?
We could, but it's something we should avoid unless absolutely required. There's dozens such sampling strategies that we could make configurable. In practice doing that often makes it harder to control noise as trying out all the combinations is too much work for users anyway, and too much work for us developers to ensure they all the combinations work well together or even measure the impact of sampling changes.
Added subscriber: @YAFU
I think using SSS I am getting different result between 2.79 release and master:
2.79:
Master:
Scene:
test_sss.blend
From master there seems to be some more noise, but also lighting and reflections change. Filter Glossy=1 does not seem to change things much.
Just mentioning this here in case there is something wrong with it, mainly in lighting and reflections.
Added subscriber: @SteffenD
