VSE/Viewport: No Audio #52337
Reference: blender/blender#52337
Windows 7 64-bit, GTX 770 OC
Broken: 2.79RC
6af7d7e
Worked: 2.78C
e92f235283
Audio tracks will only play once. There appears to be a cache which after an audio segment is cached, it no longer plays.
Playback (alt+A) through an audio clip or Audio Scrub through it and it will play the first time you go over an area; afterwards no sound is played.
Changing Sound settings in Preferences>>System seems to reset this cache, allowing audio to be played once more.
Added subscriber: @Ebone
Added subscriber: @ChameleonScales
I can't seem to have that problem with Arch Linux
Added subscriber: @Blendify
Are there any errors in the Command Prompt? This can be found with:
Info Editor --> Window -- > Toggle Command Prompt
.No but it's "currently" working in
ac28a4f
I'm not saying something was fixed or it'll stay fixed but this specific version plays audio correctly and prior versions (notably the one I mentioned) do not.
Can you try with the 2 release candidate from https://www.blender.org/download/
Is Audio supposed to play while running backwards? Because it doesn't (but it'll scrub).
Audio doesn't play if you start playing from inside the track then set the current frame to negative frames.
Added subscriber: @mont29
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
Was I supposed to provide that info/data?
I think you didn't reply to Aaron by telling if you did try on RC2
Also check the command line to see is there are any messages.
Added subscriber: @aaron-14
First reply = at Aaron and a statement that the issue is not in the specified build
Second reply = Notes on RC2 (unsure if new issues or intended)
Issue not in RC2.
Because the error occurred but no information was given as to it being fixed, it's possible the source and solution were in matters unrelated to this.
Which is why I can only say that it "works" in specific builds and to not say it is "fixed".
If no one is claiming they fixed it, it could be added again without someone knowing it's happening.
