Weight Paint (Weight-Transfer) Does not work as documented #52347
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#52347
Windows/Mac
Broken: 2.78c
Only the active vertex group is copied to the destination mesh.
The manual states "By default this tool copies all vertex groups contained in the selected objects to the target object."
Selecting the source mesh, then shift-selecting the destination mesh, then selecting Weight-Paint, and then pressing Transfer Weights.
I tested this with matching empty groups on the destination, and with no groups on the destination.
It's easy to see that only the source's active group is copied.
There is no way to select multiple or all groups on the source.
Added subscriber: @coderodent
Added subscriber: @Blendify
Added subscriber: @mont29
Yep, doc would need an update, since one or two releases this tool now uses the more generic Mesh Data Transfer one, which by default only transfers active layer. Note that in the operator redo panel, you can select 'By Name' source layers, which will then transfer all existing ones in the source to the destination mesh.
This issue was referenced by 4361
