When putting a material on an OBJ file, it TURNS WHITE!
Closed, InvalidPublic
macOS Sierra
iMac (Retina 5K, 27-inch, Late 2015)
Broken: Blender v2.9
Worked: Blender v2.78
When importing an OBJ file, (from ROBLOX) i try to put the material on, but it turns out white.
Import any OBJ file, (i use ROBLOX since i do GFX) and put the material on using the ball on the bottom left corner next to the word Object Mode. Everytime i try to put the material on, it turns white.
That's normal. Obj files often don't contain materials, so changing viewport shading mode (that "button" is a viewport shading mode, it doesn't put materials on anything) shows them shaded white.
Bastien Montagne (mont29) triaged this task as Needs Information from User priority.
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
