Update “Mystery Of The Blend” #52387
6 Participants
Reference: blender/blender#52387
The file doc/blender_file_format/mystery_of_the_blend.html is badly out of date, and just plain wrong in some respects. This set of patches tries to make it more useful.
ldo_blend_file_format_20170814.tar
Added subscriber: @ldo
Added subscribers: @Jeroen-Bakker, @Sergey
@Jeroen-Bakker, to our knowledge this doc is from you :)
Is anybody maintaining this? Otherwise perhaps it should be removed from the source tree.
Anybody there?
Hi Lawrence
Sorry for the long waait. It went under my radar intik thuis morning. Will check on it next week.
Jeroen
Hi Lawrence, can you elaborate on what you find Badly out of date and plainly wrong?
I reviewed the text, but expected more difference if you find something badly out of date and plainly wrong.
I do agree with the update of the links and adding more details to the doc, but would not add personal reflections of the file format to the doc as that is not the place to have discussions or opinions.
I also believe that the document by itself should be moved to perhaps wiki.blender.org or code.blender.org
I also believe that currently we have the option to move the rest to the
source/tools
location where currently the other tools are located.From the original text:
Wrong. “Upward” (forward?) compatibility was never a feature.
Wrong. It uses C-language structs.
Out of date. The page in question has gone.
Out of date. The default blend file of Blender 2.72 contains more than 800 of these file-blocks. Particularly since you do mention post-2.4x versions of Blender elsewhere.
Furthermore:
Does that give you enough of a start on making sense of it all?
What do you mean by “personal reflections”?
Upwards/Forward compatibility (to extend of loading data) is a demonstrated feature. See first picture of http://zgodzinski.com/blender-prehistory/
Also it is used by production houses to temp switch for some reason to a latest version of blender to do stuff and continue with the version of blender in fixed their pipeline.
That the document uses a single C-Struct to explain stuff does not make the content of the document language specific. The article is proven to be language independent. It has been used to create blend file loaders in Java, Python, Javascript, etc. . Also the document states that it is written 'to be language independent'. Is proven to be, and you say that that is not the case?
Agree the reference to the web-site is gone. this section can be removed as it is replaced with a generator that generates the website from a blend file.
Out of date blend file data. Is not out of date. A blend file from blender 2.48 still has 400 file-blocks. You can adapt it every time blender does a new release, but at the end it is not important that this document reflects the latest version. The intention of the document is to describe the blend file format.
About the rest of your comments
You explain the GLOB and USER data blocks in more depth. The original document only described the bits and bytes. Don't mind adding that.
The meaning of the data is blender version specific. It is mentioned here:
Alignment: As DNA struct must be aligned, the file data are therefore also aligned. It is not mentioned, so we could add that.
The other points have valid value to be added. Would add more wording to it though.
The rest of your points are valid so no problem adding them.
Would remove the second paragraph of your conclusion as that should IMO be part of a different document.
Sorry about the personal reflections. I have re-read the additions and I have mis-read them previously.
Where do you suggest we could add the document including the modifications?
I would recommend to move the code parts to a blender/source/tools repository and the document to the blender developer wiki.
Added subscriber: @brecht
I suggest to move the document to the developer wiki where the other code documentation is. For the source code we can point here:
https://developer.blender.org/source/blender-file/
If you want code for reading/writing
.blend
files, let me point out my own slightly more ambitious effort: blendhack.So, is this going to be removed from the source tree?
Added subscriber: @torus
I' not deep into Blender (as you are), but I wrote several parsers in the past, but I fail to parse the
.blend
files:The process of flattening a structure is not explained well enough, especially when the structure contains another structure. All documents I found root in one document that doesn't explain the process, to nobody else does. For example the only comment I received for How to interpret Blender's SDNA structure field type index? was "*Not really sure, but for what I remember (and doc/blender_file_format/ directory) you never refer to structure index, only to type index. Structure itself is linked with some type though, so you get that via reverse lookup.//"
Note "Not really sure, "... the public seems to do not know. So the document can be improved clearly .
Structures inside structures work the same way as in C—they have to. My rework explains exactly when the structure index is used, and when the type index is used. Which is just one reason why I think it’s a big improvement on the doc that’s already there!
I would like to know whether I am wasting my time.
Added subscriber: @Blendify
Hi thank you for submitting a patch, unfortunately, we no longer use the task subtype "Patch" please submit new patches through the differential tool: https://developer.blender.org/differential/
