Undo does not work in Object, Sculpt and Weight paint mode. #52444
2 Participants
Reference: blender/blender#52444
OS: MacOS 10.12.6
Graphics card: NVidia GeForce GTX 775M, 2018MB
Broken: blender-2.79.0-git20170818.ac28a4fba7-x86_64, nightly build of august 18, 2017
Worked: 2.78c, it is broken in 2.79-RC1 and several daily builds after that. Unknown if it works in the inbetween versions.
Undo does not work in Object, Sculpt and Weight paint mode. It does work in Edit, Vertex paint and Texture mode
To reproduce: enter one of the broken modes using the default cube in the default scene, change something, try to undo the action. Undo does not work.
An example: create a new scene, select the default cube. Go into Edit mode, drag out a vertex, Undo the action (CMD-Z on MacOS). This works. drag out the vertex again, go back to Object mode. Undo does not work. Go back to Edit mode. Undo works again and undoes the dragging of the vertex.
When I first installed 2.79, I copied the settings from the previous version (2.78.5, I think). When I removed the settings directory (~/Library/Application Support/Blender/2.79), Undo worked again in all modes
Added subscriber: @Robw
Added subscriber: @brecht
There's an option to disable undo for these modes, under User Preferences > Editing > Global Undo.
Do you have that setting disabled in 2.79? If so, was it also disabled in 2.78c? Or did the setting somehow change when copying over the settings to 2.79?
Hi Brecht,
At the moment, I am using 2.79 RC2 after removing the ~/Library/Application Support/Blender/2.79 directory, forcing a clean set of settings. Undo works as expected.
I retried with settings from a system backup of 18 and of 17 aug, "Global undo" is ON in both cases. Undo seems to work as expected in 2.79-RC2 in both cases.
I am happy to have the task closed as "not reproducible".
Rob.
Ok, thanks for testing, I'll close the report then.
