edit mode bevel issue
win7 64bit gtx970
Broken: 2.78c
Bevel give incorrect result.
As you can see in the image only one edge gives different bevel result.
open the file and bevel the selected edges to reproduce the issue.
thank you
Bastien Montagne (mont29) triaged this task as Confirmed priority.Aug 31 2017, 4:33 PM
Confirmed also in current master, looks like only some modes fail here, weird bug. ;)
I agree it is weird, though sometimes things like this happen because it is impossible to simultaneously set the bevels for all edges to what they should be mathematically (due to interactions with the bevels at other edges, and the code tries to "compromise" in cases like that). But I need to investigate more to see if that's what is going on here.
Howard Trickey (howardt) closed this task as Resolved.Jan 30 2018, 3:43 AM
Recent commit rB561d738eaa2f also fixed this.
