Cycles: OpenCL compiler crashes with new AMD drivers #52645
6 Participants
Reference: blender/blender#52645
CPU: Intel i5 2500k
GPU: AMD Radeon R9 390
RAM: 8Gb
Operating system: Windows 10 Pro v1703
Driver: AMD Radeon 17.7.2 / 17.8.2 (tested both)
Broken: blender-2.79.0-git.718af8e-windows64 / blender-2.79-rc2-windows64
When I use OpenCL rendering and I apply an UV Map with an image texture, appropriate kernel file(s) can't be compiled resulting in a crash of Blender. Rendering without the image seems to work fine.
This might be an issue because of a rather new driver. I haven't been using Blender for that long yet, so I can't say if older driver versions work properly or not. I would be very interested to know if there are older driver versions that work well, so I can roll back to that specific version, if that's an option.
uvtexture_test.blend
cycles-debug.txt
Added subscriber: @lennardh
#52970 was marked as duplicate of this issue
#52868 was marked as duplicate of this issue
#52821 was marked as duplicate of this issue
#52589 was marked as duplicate of this issue
Added subscribers: @MaiLavelle, @dfelinto
@MaiLavelle can you confirm/triage this one?
Looks to be the same compiler crash from #52589. Not sure if there's anything we can do as there's no proper error from the compiler. I don't think reverting to older drivers will help in this case either, as the crash is likely an existing issue triggered by some code change we made at some point. Maybe someone could bisect this, could help the compiler team in getting this fixed.
Added subscribers: @bliblubli, @LukasStockner, @mont29
Blender crash using OpenCL rendering when UV map with image texture is usedto Cycles: OpenCL compiler crashes sometimes while building kernelsDriver 17.7.1 works, 17.8.2 doesn't, for both files
This comment was removed by @bliblubli
RC1 doesn't work, build from 21 July does with 17.8.2
driver 17.9.1 resolves the bug.
Version: blender-2.79.0-git.718af8e-windows64
I can confirm that 17.7.1 works.
Tried 17.9.1 with a clean install, crashes in the same manner as with driver 17.7.2 / 17.8.2
@lennardh both your file and my file rendered on latest buildbot using 17.9.1 on RX480. I did a normal install from 17.7.1, but OpenCL driver should have been actualized. I'll try today on Vega to see with clean install.
I can confirm 17.9.1 still crashes on Vega and RX 480 with another machine and a clean install. It seems somehow the OpenCL driver wasn't actualized with normal install. So in the meantime, staying on 17.7.1 is recommended.
Added subscribers: @Julian-4, @LazyDodo, @t0xik, @Sergey
Cycles: OpenCL compiler crashes sometimes while building kernelsto Cycles: OpenCL compiler crashes with new AMD driversAdded subscriber: @brecht
Changed status from 'Resolved' to: 'Open'
Reopening since this is not solved.
Added subscribers: @YaroslavVasilyev, @FloridaJo
Added subscriber: @FrontBack
This issue was referenced by blender/cycles@ad2001adfa
660e8e59e7
