Cycles 3/6 textures reversed on cube with generated co-ordinates and box mapping #52652
Reference: blender/blender#52652
Win 7 64bit - Geforce GTX 670
Broken: 2.78
4bb1e22
and 2.797b397cd
Worked: unknown
When applying a texture to a cube in cycles, using generated co-ordinates and a box projection for the image mapping, 3 of the 6 faces have their textures applied back to front (also occurs with object co-ordinates and flat mapping). This behaviour is consistent in the viewport (material and rendered modes) and also in the render result. Adding a cube with generate UV's ticked does not correct this problem.
In the example file and attached image, the cube on the left indicates this behaviour. The cube on the right uses a custom UV map and flat projection for image mapping to achieve what I would consider the most appropriate result, for texturing a simple cubic object.
Add cube
Create material node setup using image texture:
File example - Cycles cube generated texture coords backwards Packed.blend
Added subscriber: @JohnDennis
This issue was referenced by blender/cycles@71d4df8e0c
dd8016f708
Added subscriber: @brecht
I think we can tweak the mapping to avoid this, even if it means break backwards compatibility a bit.
