Error : Out of Memory
Im getting the error : out of memory. When i press shit+z render view or f12 to render i go to render window and stop with a error out of Memory. I tried with CPU and GPU but the result same. I tried render in original file and also i group and make a new file and link the group and render still same result. I have Ci5 with 8GB RAM and 2 GB Graphic card. I dont have much complex scene. Im using 2.78c version of Blender. May i know the reason why i cant render my model and get rid out of this error.
Brecht Van Lommel (brecht) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Sep 6 2017, 12:47 PM
There's not enough information in this report for us to investigate, please provide all the information as requested here:
https://developer.blender.org/maniphest/task/edit/form/1/
Particularly test the Blender 2.79 RC, and provide us a .blend to reproduce the problem.
https://www.blender.org/download/
I suspect there is something unexpected in the scene causing a lot of memory usage, it can be a shader with a very high resolution texture, a modifier that generates a lot of geometry, etc. Usually the best way to detect that is to incrementally remove objects and materials from the scene until you narrow down the cause.
This is my scene and no texture or emission just a hdri image and material to the model. As i have send the above image with out memory i have today problem i just click and im on the desktop blender shutdown. Plz tell me what else u need information i will provide. Thanks
Please check this page with info about how to create a report.
We need the operating system, graphics card, Blender version, and the actual .blend file and hdri image to be able to investigate this. A screenshot is not sufficient information for us. To debug this kind of thing yourself you can incrementally remove objects and materials from the scene until you narrow down the cause.
More than a week passed without a reply.
Due to the tracker policy, archiving until the required additional information / data is provided.
