Dupligroup rotation doesn't respect its offset
Closed, InvalidPublic
Win7 64bit
Broken: 2.79c (Both BI and Cycles)
Rotate Dupligroup (Wire cube) while viewport rendering. See how Object Info's Location produces different values regardless of given offset to the group.
Brecht Van Lommel (brecht) closed this task as Invalid.
Object Info > Location gives you the location of the object origin, which for the Cube object in this file is not at the center of the cube. So if you rotate the empty that is instancing this cube, that origin actually moves to a different location.
