Radeon Pro Render cant enable
Closed, InvalidPublic
Windows 10 and amd radeon g7 2gb
Blender 2.79
Cant enable Radeon Pro Renderer. I install the addon and allways get these errors when i click to enable:
File "C:\Program Files\Blender Foundation\Blender\2.79\scripts\modules\addon_utils.py", line 350, in enable
  mod.register()
File "C:\Users\ΡΑΦΑΗΛ\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\rprblender\__init__.py", line 161, in register
  from rprblender.render import engine
File "C:\Users\ΡΑΦΑΗΛ\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\rprblender\render\engine.py", line 19, in <module>
  import rprblender.render.viewport
File "C:\Users\ΡΑΦΑΗΛ\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\rprblender\render\viewport.py", line 9, in <module>
  from rprblender import sync, export
File "C:\Users\ΡΑΦΑΗΛ\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\rprblender\sync.py", line 14, in <module>
  from rprblender.core.nodes import log_mat, Material, ShaderType
File "C:\Users\ΡΑΦΑΗΛ\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\rprblender\core\nodes.py", line 13, in <module>
  import rprblender.node_editor
File "C:\Users\ΡΑΦΑΗΛ\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\rprblender\node_editor.py", line 3, in <module>
  from rprblender.nodes import get_node_groups_by_id
File "C:\Users\ΡΑΦΑΗΛ\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\rprblender\nodes.py", line 869, in <module>
  from .node_thumbnail import get_node_thumbnail
File "C:\Users\ΡΑΦΑΗΛ\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\rprblender\node_thumbnail.py", line 24, in <module>
  import pyrprx
ImportError: No module named 'pyrprx'
hi, you will need to ask the author of the addon to help/fix any errors, this tracker is for addons that come with blender by default.
thanks.
Closing as invalid.
