Percent mode in Bevel operation does not work.
Windows 7 64bit with latest updates, GTX 780 6GB edition, Intel i5 4670K
Broken: 2.79 (official)
Worked: 2.78a (official)
Using the percent mode in the Bevel operation does not give a result. Other modes work fine. The value for determining the amount of Bevel suddenly looks like this: 1.#QNAN0
  1. Open default scene.
  2. Slect default cube and go into edit mode.
  3. Press CTRL+b to enter Bevel operation.
  4. Assign a value.
  5. Go into "Percent" mode.
  6. Nothing will happen, your selected edge won't show. Bevel value can not be assigned.
Related Objects
Vuk Gardašević (lijenstina) triaged this task as Confirmed, Medium priority.
I can confirm with 2.79 factory startup, selecting an edge > ctrl +b > pressing M for flipping through modes until percent is chosen. The percentage gets a -1.#QNAN value.
Note the task was originally referring to Boolean but clearly points out to Bevel.
Vuk Gardašević (lijenstina) renamed this task from Percent mode in Boolean operation does not work. to Percent mode in Bevel operation does not work..
Bart (BlackBart) added a comment.EditedSep 13 2017, 10:30 PM
Yes sorry. I was really tired when I wrote this post, still am. Don't know how I managed to confuse the two. Sorry again.
Just for info. I opened one of my older files created in 2.78a. Bevel in percent mode worked fine.
Strange, it works fine for me on Linux. I will try on Windows when I get a chance and see if I can reproduce there.
Hm, going back and retesting there seems to be a difference between enabling the debug option or not.
Starting with blender --factory-startup -d seems to produce the error while without the -d argument it doesn't.
Thanks, can confirm that that happens now.
