.obj import to cycles crashes the program.
Windows 7 Pro SP1 Nvidea Geforce 970
Blender 2.79. Function not available in 2.78c.
Import an .obj. Try viewing object in rendered mode and program crashes.
Took a saved .obj with simple data (diffuse and specular values only) and opened it in Blender With Cycles render selected, checked node editor. 18 nodes set up (for what should only be, at most, 3 nodes). Select method of display as 'rendered view', program crashes.
Sergey Sharybin (sergey) triaged this task as Needs Information from User priority.
Can not reproduce the issue, but the files are missing texture which might be essential for this issue to happen. So:
  • Provide all dependent files (maybe there's something else apart from the texture?)
  • Try packing all images into .blend file and render then and see crash still happens.
If OBJ file has:
mtllib  wall section test.mtl
importer doesn't find correct mtl file (tries 'wall' 'section' and 'test.mtl')
so spaces there in filename are one problem.
Thank you both. Your answers helped me to identify the cause. The other program compiling the .obj (exporter) is creating corrupt images of the materials, and I suspect this faulty code is causing Blender to crash. After manually replacing the texture images in the export file with valid images, the Blender import to Cycles worked fine.
BTW, I had tried 4 different objects before posting here and all had resulted in the same issues. My bad for not including the exporter in the possible fault line.
This can be closed, no bug here....
Can you attach an example of corrupted image? I would like to see if we can make Blender to identify such images and prevent crashes (rendering magenta-color as a missing texture for corrupted image is more friendly than crashing)
Sure. I also did another experiment. I exported a model from Poser as an .obj. I did this twice, once with full texture path names and once exporting the textures to the folder.
With the first one I opened the .mtl file and checked the texture path. It is valid and accurate. When importing to Blender that texture shows magenta in material view and if I try rendered view the program crashes. If I then physically search for the image from the cycles node it works. For some reason Blender is not following the path automatically, but can do so if I manually point it to the file.
The second option (exporting the textures) results in the corrupted images.
I can't view this in Windows picture viewer and the size of the file is different to the original.
Can you maybe save .blend file with all the referenced textures etc, pack them to an archive? But also weird why importing doesn't happen correctly. Perhaps worth separating two reports:
  1. Crash when special "corruption" happens.
  2. MTL is not imported correctly.
Bastien Montagne (mont29) closed this task as Archived.
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
