Euler Filter doesn't work
Open, ConfirmedPublic
Windows10 and GTX980
Broken: 2.79
Joshua Leung (aligorith) triaged this task as "Incomplete" priority.Thu, Sep 14, 7:58 AM
Joshua Leung (aligorith) claimed this task.
There is insufficient information here to do anything about this report.
Please include an simple example file and a set of clear instructions for how to reproduce the problem you're encountering.
Oh, I found the way to upload the file. The problem is that euler filter doesn't solve the euler rotation jump in Graph Editor. The scene file I've uploaded has a cube with the rotation function curves and they are not continues. Please have a look and make a solution.
Joshua Leung (aligorith) raised the priority of this task from "Incomplete" to "Confirmed".Thu, Sep 14, 8:46 AM
Thanks, I'll see what we can do about this :)
Joshua Leung (aligorith) changed Type from Bug to To Do.Sat, Sep 16, 7:46 AM
Ok, I've double checked. Officially this isn't a case that the current code was intended to address (i.e. it only fixes the most basic case).
Therefore, as per our tracker policy, technically this is a todo-item, not a bug.
