Displacement don't anymore support object coordinates for textures.
Win 10 gtx 960
2.79
Weird distortion to the displacement even when the texture works perfectly when used as a color in the material node. Distortion: https://imgur.com/a/LI6ei
Texture works:
https://imgur.com/a/AhUXg
Link to file: https://www.dropbox.com/s/99xrpg9jhqd0viy/texture%20coordinates.blend?dl=0
Use image texture in object coordinates as a color for diffuse and to displacement. The displacement does not work.
LazyDodo (LazyDodo) triaged this task as Needs Information from User priority.
Please attach a .blend showing the problem, don't forget to pack the textures.
Mai Lavelle (maiself) raised the priority of this task from Needs Information from User to Normal.
The image node is set to box projection, which might be using the wrong coordinate system during bump evaluation.
Brecht Van Lommel (brecht) closed this task as Resolved.
This appears to be solved in the latest daily builds.
