Assert in looptri calculation after recent changes #52852
Reference: blender/blender#52852
Latest master, debug build with tests enabled, while running cycles_report_test i'm hitting the following assert when running the T42475_1/2 tests.
yet the test still gets marked as a 'pass'
full log:
cycles_report.txt
Added subscriber: @LazyDodo
Added subscribers: @Sergey, @brecht
This is new code from
9591b5f618
.Just open the .blend and it will show that backtrace already, no need to start a Cycles render:
T42475_1.blend
[Ctest/cycles_report_test] Assert fires, test still succeeds.to Assert in looptri calculation after recent changesWhile the assert might not be auto testing related I really wish that this test wasn't marked as a pass, if i hadn't been randomly paying attention to the terminal, this would have just scrolled by and marked as a 'pass'
Right, it will only crash when building with
WITH_ASSERT_ABORT
. Not sure what the best way is to solve that, perhaps a--debug-abort
command line option to enable aborting at runtime?Our asserts by default do not error, only print the warning, autotest has nothing to do with that… There is a switch to actually abort on failed asserts iirc, could be useful to enable it for testing (can't remember exactly how, build option, envvar, …).
Assert is just wrong here btw, fix incomming.
This issue was referenced by
25f28d348f
There seems to be some varying behavior with asserts. This one silently failed while marking the test as succeeded, #52853 displayed a popup (abort to quit, retry to debug, ignore to carry on) which blocked further tests from running, given running ctest on a debug build took around 2 hours, not having to baby sit incase any ui shows up would be prefered. I'm not overly picky with any changes here, if WITH_ASSERT_ABORT does the trick i'll happily add that to my debug builds.
The difference is that Cycles uses the standard
assert()
which will abort, while Blender usesBLI_assert()
which doesn't. I guess building withWITH_ASSERT_ABORT
is ok. For the popups D2850 is a solution.
