Blend2Unity
Hi,
I came up with this addon while working on my recent project.
"Export to FBX" button allows to export models to FBX with proper transformation and preserved smoothing groups. It also sets the pivot on the lowest vertex and provides the possibility to export as one file or multiple files.
"Export texture set" button converts Roughness map to Smoothness as Base Color or Metallic alpha channel.
"Export unitypackage" allows to export model with textures (converted roughness to smoothness as alpha) to single *.unitypackage file
Limitations:
  • To properly export Unity Package file you have to use Blender in version 2.79 and Principled BSDF shader. You will get best results with textures connected directly to Prinsipled BSDF node (without rgb curves, color ramp etc., normal map is an exception). The addon searches for maps connected into following inputs: Base Color, Metallic, Roughness, Normal
  • Converting Roughness to Smoothness requiers a lot of calculations and it's a time consuming task (approximately 30 seconds for 4k texture) so don't worry if Blender will look like it stuck.
https://i.imgur.com/yOZipIu.gif
https://i.imgur.com/MT4hyZz.png
https://i.imgur.com/ht2Y0aT.png
https://i.imgur.com/nO6DnLj.png
Addon can be downloaded here:
https://gum.co/eXkfO
or from the attachment:
Vuk Gardašević (lijenstina) triaged this task as Normal priority.
Brendon Murphy (meta-androcto) closed this task as Archived.
hi, thanks for submitting your addon, It looks useful and creative. Sorry for delays. Currently we are archiving all 2.79 related addons.
Please feel free to submit a new task for this addon when it's updated to Blender 2.8.
Thanks for your participation and we look forward to seeing you again soon.
